Remove Gas Tank - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-04-2011, 10:05 AM Thread Starter
Date registered: Mar 2011
Remove Gas Tank
I am trying to remove the gas tank in our 1976 450SL. I have the plate in the front of the trunk out and the four bolts on the tank. What else is holding it in? I see a large nut on the bottom of the tank. Do you have to take that loose also to remove it? Any help would be appreciated on this.
Thank you.
Beenzen is offline
post #2 of 3 (permalink) Old 03-05-2011, 04:54 AM
ktmripper's Avatar
Date registered: Jun 2010
I will look later today, but I think there is a vent hose to disconnect behind the license plate. Also make sure the filler neck does not hang up. undo fuel lines too (if you have not) The large brown nut on the bottom is the tank drain/ screen.
ktmripper is offline
post #3 of 3 (permalink) Old 03-05-2011, 05:34 AM Thread Starter
Thank you for the reply Sir. So the 4 bolts is the only ones in the tank? Do you have to pull the strainer on the bottom or will the tank come out with it in it? I have the bolts out of it but it seems like it dont want to move much.
Beenzen is offline
    W202 - how to remove gas tank Benzguy888 W202 C-Class 2 04-18-2011 09:06 AM
    Malfunction / error gas tank (reserve) with tank full MBSLR230 R230 SL-Class 0 09-29-2009 10:20 AM
    When I Fill My Gas Tank the Gas Gauge Shows Empty - Why?? Schantzie240 C208/A208 CLK-Class 9 12-23-2008 04:04 PM
    Fuel tank takes quarter tank full of gas less than what it used to take! Labik34 W140 S-Class 13 07-19-2008 04:15 PM
    Was something loose? I filled my gas tank, and my fuel meter never reset to the full tank reading.. AC_ML W163 M-Class 5 08-20-2004 07:12 AM
