1979 280SE fuel problems - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-26-2011, 10:43 AM Thread Starter
Date registered: Oct 2008
Hi my son has a 1979 280se. It has ran fine until the other day. He went to start it and it would just turns over but not start. I checked it out and it sounded like a clogged fuel filter. I could prime it and get it to start but not continue to run. I replaced the fuel filter and it started and ran, reved up and ran for about 5 minutes then shut down again. I would prime it and have the same original problem. I transported the car home and two days later tried to start it and it started again but only for about 2 minutes. I checked the voltage at the pump while it was running and got 13+ volts. There is no voltage at the pump with just the key on and the engine not running. Qeustion:
1-Could it be the relay? and if so where is it and how can I check it out?
2-Does anybody has a list of the fuses?
3-What other things can I check out ?
lchoyt is offline
    1979 280se - premium or regular fuel syscon W116 S, SE, SEL, SD Class 2 09-15-2010 04:13 PM
    FS 1979 MB 280SE knockdown For Sale/Wanted/Trade/Giveaway 7 03-08-2010 01:23 PM
    1979 280SE manual on Sacramento CL bondavi W126 S,SE,SEC,SEL,SD,SDL Class 7 01-04-2010 12:37 AM
    1979 280 SL with a 280SE engine in it Tweetie13 General Mercedes-Benz 0 07-23-2009 03:07 PM
    280SE fuel pressure problems Dollar69 W126 S,SE,SEC,SEL,SD,SDL Class 0 09-24-2002 11:02 PM
