220D Neutral Safety Switch - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-18-2011, 12:30 PM Thread Starter
Date registered: Dec 2010
Vehicle: 1969 220D
Hi all
I have a '69 220D with column shift automatic. I need to replace my Neutral Safety switch, as I traced my inop backup lights to it. However, to get the switch off the shift linkage needs to come out of the transmission. I cannot figure out how I am supposed to get that shaft off, there is no bolt or nut on it, it just goes in through the switch and disappears. Does anyone know how that comes off?
Thanks
-Dan
danvw1 is offline
post #2 of 6 (permalink) Old 02-19-2011, 02:48 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
I'm not sure if the 1969 is a bit different from the later models of the 1970s, but there the shaft can stay put, you just need to remove the lever, it has one securing bolt at the bottom. It goes through at the red dots in the picture below. Take the bolt out and remove the lever. Than remove the two bolts which hold the NSS (near the blue dots).
And than you have this:
Govert70227 is offline
post #3 of 6 (permalink) Old 02-19-2011, 04:19 PM Thread Starter
Vehicle: 1969 220D
My setup is different than that. The lever is attached to the shaft and there is no bolt holding it on, and I cannot see any type of clip.
danvw1 is offline
post #4 of 6 (permalink) Old 02-22-2011, 06:22 AM
Quoted: 4 Post(s)
Interesting, I don't think the whole shaft has to come out, there must be some screw. The part picture in the EPC suggests that it is behind the NSS.
post #5 of 6 (permalink) Old 03-13-2011, 10:28 AM Thread Starter
Vehicle: 1969 220D
I have been messing with this all day. There is no screw holding the lever to shaft, it is all one piece. I looked in the EPC and the lever/shaft combo they have listed looks different than mine. Is it hooked inside the transmission?????
Here is some more info
Transmission #
115-270-04-01
danvw1 is offline
post #6 of 6 (permalink) Old 03-14-2011, 04:04 AM
Quoted: 4 Post(s)
Can you knock the lever from the axle? It seems to be two seperate pieces. Perhaps heat the lever so it expands?
The transmission number means it is a 722.107 transmission. Early 220Ds had 722.206 transmission.
    Neutral Safety Switch sanzala W123 E,CE,D,CD,TD,TE Class 1 02-16-2011 08:57 AM
    neutral safety switch hankG. General Mercedes-Benz 0 03-24-2010 06:41 PM
    Neutral safety switch topbanana3767 W124 E,CE,D,TD Class 5 02-28-2010 12:07 PM
    Neutral Safety Switch stout W124 E,CE,D,TD Class 1 11-27-2008 09:27 PM
    Neutral Safety Switch/Backup Light Switch SC Surfer W123 E,CE,D,CD,TD,TE Class 13 01-18-2008 02:45 PM
