M189 "Big Six" Motor - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 02-16-2011, 10:22 PM Thread Starter
trazique's Avatar
Date registered: May 2008
Vehicle: '95 E320 Wagon '99 CLK430, 62 220se, 64 220se, 65 220se, 66250se, 85 380sl, 90 190E 2.6
Quoted: 57 Post(s)
Send a message via Skype™ to trazique
Post M189 "Big Six" Motor
So I lucked up... I purchased 4 W111 for $3k along with a Bunch of extra parts including 4 motors and 3 trannys one of the cars is a 66 250se that has an all aluminium M189 3.0 in it (the green one). This motor has an extra free spining wheel on the back of the harmonic balancer that spins for a few seconds after the engine shuts down. but when you rev the motor it majkes a sound as if its binding or some bearings are worn does anyone have any info on this thing? i can post pic if needed.
trazique is offline
post #2 of 9 (permalink) Old 02-16-2011, 11:28 PM
benzmizer's Avatar
Vehicle: 1983 240d AT; 1993 e320 AT
Quoted: 4 Post(s)
Yeah, please do.... include the 4 W111 too. Congratulations!
benzmizer is offline
post #3 of 9 (permalink) Old 02-17-2011, 12:09 AM Thread Starter
trazique's Avatar
Quoted: 57 Post(s)
So here are some pics of the cars... as you can see I wasted no time, I got right to it with the restoration on the 62 220se which only had surface rust (all solid)next woould be the green 66 250se which has the ''BIG SIX'' in question it needs floors and third would be the black top I think 64 or 65 220se... and the blue in the back ground is a doner.... thanks guys. BTW I have better pic of my progress
Name:	2010-08-25 22.52.54.jpg
ID:	357656   Click image for larger version
Name:	2010-09-06 18.09.52.jpg
ID:	357657   Click image for larger version
Name:	2011-01-01 17.47.45.jpg
ID:	357658   Click image for larger version
Name:	2011-02-01 17.03.37.jpg
ID:	357659   Click image for larger version
Name:	2011-02-01 17.03.30.jpg
trazique is offline
post #4 of 9 (permalink) Old 02-17-2011, 12:40 AM
DanW114's Avatar
Date registered: Jan 2011
Nice one! I think a W111 coupe will be the next car I add to the collection.
DanW114 is offline
post #5 of 9 (permalink) Old 02-17-2011, 12:40 PM
Cool, I would have done that deal also.
Brian O
bostosh is offline
post #6 of 9 (permalink) Old 02-17-2011, 03:31 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Great find, they will make some good looking cars
1984babybenz is offline
post #7 of 9 (permalink) Old 02-18-2011, 06:28 AM Thread Starter
trazique's Avatar
Quoted: 57 Post(s)
Thanks guys, It is exciting.
trazique is offline
post #8 of 9 (permalink) Old 04-22-2011, 01:08 AM
Date registered: Jun 2004
Quoted: 7 Post(s)
Are you sure the W108 is a 250SE and not a W108 300SE ? .They made 2700 (plus) 300SE W108's between 1965 and 1967 . No air suspension and they had a m189 engine (189-986 or 189-989 ) .These were the original factory hot Rod sedans before the V8's came out. A rare car anywhere today,especially in the US.
Regarding the 'spinning wheel" on the front of the engine. The damper has come to peices and needs to be repaired . it has six springs and two rubber blocks inside which work by pushing a brake disc against the large outside wheel to dampen down vibrations.
mercmad6.3 is offline
post #9 of 9 (permalink) Old 04-25-2011, 04:42 AM Thread Starter
trazique's Avatar
Quoted: 57 Post(s)
I see... Well this one (the green one ) is actually a 66 W111 250se accordong to the classic centre in cali and the vin. But thats is interesting to know though, Whom ever did the swap did an excellent job!
Also, the motor has an electro clutch I can tell it's proberbly not a factory build because the electro fan clutch plate is welded to the carrier I guess the car didn't have the circuitry to operater the clutch.
As far as the damper, I did take it apart and saw there were no rubber nor springs, it was just the two plates sandwished together but there were two wierd looking plastic disks between the mail damper and another between the block and the free spinning disks, where one of those plastic disks/washers were damaged.
However I thank you all so very much for your responses and info.
Regards...
trazique is offline
    "617 - "Oh, that TRACTOR motor"...... !!!! bondavi W123 E,CE,D,CD,TD,TE Class 2 01-17-2011 11:46 PM
    Merkels election shows that "Big Spending" is losing its luster TNTRower Off-Topic 9 09-30-2009 04:41 PM
    Today's "Big Lie" from the Right: "Pelosi called us un-American" FeelTheLove Off-Topic 23 08-11-2009 08:11 AM
    Romney says he'd take Veep, calls McCain "Big Dog" Jakarta Expat Off-Topic 2 03-11-2008 06:25 PM
