114 230.6 TUNING - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-16-2011, 07:09 AM Thread Starter
Date registered: Feb 2011
114 230.6 TUNING
Hi All
I wonder.....can anyone show details for tuning a 230.6 w114 with a 180.954 motor
Looking for valve clearances, points gap, dwell, idle co%, plug gap etc.
I've just checked the valve clearances, and they didn't exist basically! So it now has a 'gap' to start with, but any help would be appreciated
CarsOrBikes is offline
post #2 of 4 (permalink) Old 02-16-2011, 07:33 AM Thread Starter
My own opinion is a valve has burnt, poss exhaust as it spits in the ex manifold and has a non electrical misfire it seems, as if plug caps are pulled while running, they all make a difference, comp was down by 50psi on two cyls, and like I say, no feeler at all would go in most of them when checked, 2thou in a few of them only.
At least it runs, which it wouldn't do before :-)
post #3 of 4 (permalink) Old 02-16-2011, 08:46 AM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 36 Post(s)
Exhaust Cold--.007 (.18 mm)
Intake Cold--.003 (.08 mm)
Point gap--.012 (.3 mm)
Dwell--39-41 degrees
Timing--TDC @ idle; 37 degree BTDC @ 4500 rpm
Spark Plug Gap--.028 to .032 (.7 to .8 mm)
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #4 of 4 (permalink) Old 02-16-2011, 10:15 AM Thread Starter
Very kind,
Thankyou, will fettle some more ....
    SLK TUNING - Bridging the gap between tuning an untunable car... forcefedboost R170 SLK-Class 9 05-06-2010 11:24 AM
    my 114 Cam Vintage Mercedes-Benz 3 07-25-2005 05:01 AM
    Chip-tuning and Tuning MB in Russia and CIS BiPower General Mercedes-Benz 2 08-08-2004 02:37 AM
    how much faster is the slk 320 vs the 230? 0-60? 1/4? is the 98 230 slower than say a 2001 230? RaVEr R170 SLK-Class 12 04-09-2002 04:27 PM
    ECU tuning update for '01 SLK 230 GreenSLKGuy R170 SLK-Class 6 04-05-2002 02:18 PM
