Thinking about buying a 65' 220SE coupe. - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-13-2011, 06:12 PM Thread Starter
PzGren's Avatar
Date registered: Apr 2010
Vehicle: W123 & W116
Exclamation Thinking about buying a 65' 220SE coupe.
While driving around I came across a 1965 220SE. The car has some body rust, nothing major, bad paint, worn interior, and 140k miles. It stared with a bit of hesitation but stayed running. The guy want's 7K for it. Is it really that valuable? Are the relatively rare? I'm not used to Mercedes this old and don't know what to think of it. I'm pretty sure I could get the price down... Is this car worth 7K or any where around that price?
'73 W116 450 SE
'74 W115 230
'77 W116 450 SEL -Armored version
'80 W116 300 SD
'80 W123 300 TD -junked
PzGren is offline
post #2 of 6 (permalink) Old 02-13-2011, 07:42 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 33 Post(s)
There's one on ebay right now selling at $7100.
Mercedes-Benz : 200-Series - eBay (item 130482957290 end time Feb-14-11 17:00:00 PST)
The one you're looking at looks a little rougher, though. You will want to inspect it underneath very carefully if you want to buy it.
They are a very desirable car. Be prepared for a lot of expense sorting it out.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #3 of 6 (permalink) Old 02-14-2011, 06:39 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
If it has any visible rust it is certain to have rust where you can't see it. If you are serious put it on a lift so you can do a underbody inspection. Chassis parts are common but everything else is exclusive to this car-nothing on the body exchanges with any other car including glass and bumpers. Don't make a impulse buy on on of these-spend time seeking out a clean car with history.
Good luck!
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #4 of 6 (permalink) Old 02-15-2011, 03:43 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
I owned a 1964 and had to replace all the fenders due to rust. The area above the headlamps is especially prone to rust. Check to see if these have been repaired. Lift up the trunk mat ans check out the floor. That rubber mat traps moisture in the trunk.
Ed Mclass is offline
post #5 of 6 (permalink) Old 02-16-2011, 09:43 PM
trazique's Avatar
Date registered: May 2008
Vehicle: '99 CLK430, 62 220se, 64 220se, 65 220se, 66250se, 85 380sl, 90 190E 2.6
Quoted: 57 Post(s)
Send a message via Skype™ to trazique
It is true about the rust issues I have $ ot them which 1 is already restored check the floors, left and right side in trunk, top of rear wheel wells and under carriage. put it this way, front bumbers alone from the dealer is $1900 to $2500... do some research.
trazique is offline
post #6 of 6 (permalink) Old 10-23-2012, 02:37 PM
Date registered: Oct 2012
I would agree. Don't buy this car without shopping around for better alternatives. Fall in love with "a model or type of car" not with "a specific car of that model/ type". It is always cheaper to buy a good one than thinking you are going to safe by fixing up a "not so good one".
Peter De Cabooter is offline
    Thinking of buying a 2002 C230 Coupe Karlzberg General Mercedes-Benz 3 05-18-2009 12:53 PM
    Thinking of buying a 2005 C230 Sport Coupe NeoScotty W203 C-Class 3 08-29-2007 06:59 PM
    Thinking of buying a C230 coupe mtcurrie W203 C-Class 1 06-14-2007 02:09 PM
    Thinking about buying a 1995 s500 coupe abdoul W140 S-Class 5 03-24-2004 05:50 PM
    Thinking of buying a W140 Coupe joe defrancisci W140 S-Class 4 10-08-2002 08:10 PM
