1970 300SEL no forward gears update - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-08-2011, 06:07 AM Thread Starter
Date registered: Aug 2010
Ok, I got in touch with a trans part supplier in Houston (jie.com). Very helpful! Spoke to Jurgen; he advised me to pull the pan and valve body and inspect the rearmost band. Jurgen knows his transmissions. The rear band was broken on the servo side (wouldn't clamp against the drum). Now my question is: is there anyone with Auto Trans experience that can help me? IE does trans need removal or is this an in chassis fix? Are there any other concerns while I'm here and so on. If you have Auto Trans concerns give JIE a call!
SOLVED R&R trans and replaced rear band and front two bands for good measure. Replaced seals and valve body gasket and reinstalled. Satisfactory road test. Now on to next concern...........
sedgar2 is offline
    All Gears move car forward jek9372 W201 190-Class 1 01-14-2015 05:21 PM
    All gears moving forward even in reverse jcb928 W126 S,SE,SEC,SEL,SD,SDL Class 8 11-03-2010 02:29 AM
    W140 400sel. No forward gears. phillipgarside W140 S-Class 2 08-05-2010 06:17 PM
    95 c220 transmission - no forward gears jdudenhe W202 C-Class 2 05-28-2010 06:41 PM
    350SDL no forward gears kanoti W126 S,SE,SEC,SEL,SD,SDL Class 4 10-24-2004 06:01 PM
