Newbie needs help - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 02-01-2011, 08:37 AM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 108 Post(s)
You have a mixture of bad gas and maybe a timing issue. You need to go through the system and start clearing out the gunk. I would pull the fuel distributor and clean it with carb cleaner, do the same with the injectors. You you say that you emptied the tank, did you remove the fuel strainer? If not, then you need to remove it as it may be loaded with crud which will cause poor fuel flow or fuel pressure.
Go to the R-C 107 forum and ask there. There are lot of people who have discussed waking up a car after a long sleep.
Good luck.
With best regards
Check out the W114, W115 /8 enthusiast forum
My 280SL restoration
alabbasi is offline
    Another newbie daddy coole General Mercedes-Benz 3 11-10-2009 07:24 AM
    Newbie Here donnyb General Mercedes-Benz 1 10-04-2009 01:56 PM
    Another newbie here eddie84 General Mercedes-Benz 1 10-04-2009 01:55 PM
    Hi everybody!!!Newbie here TA72 General Mercedes-Benz 1 08-29-2009 08:36 PM
    Newbie with Newbie Issues.. ggfoxx W203 C-Class 2 12-10-2005 08:04 AM
