Ignition retrofit on 74 450SLC? affect injection? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-20-2011, 11:30 PM Thread Starter
Date registered: Jan 2011
Vehicle: 1974 450 SCL, 1984 300 sd
Anyone have info on circumventing the $tock points/tran$i$tor box ignition with some aftermarket electronic system? Would it cause issue with the injection system?
Mecheng.fea is offline
post #2 of 3 (permalink) Old 01-21-2011, 12:35 AM
wbain's Avatar
Date registered: Dec 2003
You can very easily swap to a more modern ignition setup. The EFI has trigger points lower in the distributor case. Don't mess with those.
wbain is offline
post #3 of 3 (permalink) Old 01-21-2011, 06:57 AM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 34 Post(s)
I replaced the ignition in my '72 280SEL 4.5 (same engine) with a new ignition from Pertronix. I installed the Pertronix 1885 with the Flamethrower coil. Not expensive and worked great the first time. Takes about an hour to install. It gets rid of the ignition box and the ballast resisters, but does not affect the D-Jet Fuel injection.
There are several threads about this. Search the forum with Pertronix as your search phrase.
TZ_280SEL is offline
    Quick way to test if it's the Shut-off Valve @ Injection vs Ignition? Dieselbenz.info W123 E,CE,D,CD,TD,TE Class 4 09-27-2010 08:33 AM
    1973 450SLC ignition loumerc R/C107 SL/SLC Class 32 03-16-2010 11:38 PM
    250se injection pump (and bnz club injection repair manual) JJsAtoZatAz@MSN.COM For Sale/Wanted/Trade/Giveaway 1 02-19-2010 12:01 AM
    Electric fuel injection for 450slc bluefang R/C107 SL/SLC Class 5 03-28-2007 05:40 PM
    fuel injection relay & msd ignition The Big Kahuna W126 S,SE,SEC,SEL,SD,SDL Class 1 04-14-2006 03:44 AM
