Leaking front air suspension - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-11-2011, 07:02 PM Thread Starter
Date registered: May 2009
Vehicle: 1985 380SL; 2004 E320; 2007 GL450
I just bought a 72 380SEL 4.5. I am going to pick up the car. The owner told me that there is a leak in the front air suspension so the front is lowered after the car is parked for a while. The front will be raised to normal position in 3-5 minutes after starting the engine. I am suspecting that there is condensed water in the air tank. So I want to discharge the air tank before I driver the car home.
I have a question on how to discharge the air tank. Is it just to unbolt the bottom bolt in the air tank to discharge?
Anything else I should pay attention to drive the car 200 miles the first time by me?
Thanks in advance.
bluewater1 is offline
post #2 of 4 (permalink) Old 01-11-2011, 08:10 PM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 116 Post(s)
Air tank has valve at the bottom. Pull it to the side and it will open and condensation will drain. Release when water drains out. Don't empty tank. Of course that is not going to fix a leak.
Have you bought it site unseen?
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #3 of 4 (permalink) Old 01-11-2011, 08:32 PM Thread Starter
Thanks. I know discharging the air tank will not fix the leak. I just want to drive the car home safely and then fix the leak.
I bought the car on ebay so I have not seen it in person. I have seen pictures and knows the history of this car very well as one of the members of this forum knows this car very well. It has been taking care of by previous owners.
post #4 of 4 (permalink) Old 01-12-2011, 06:14 AM Thread Starter
Originally Posted by king DE View Post
Does anyone have a PDF of the exploded view of the sunroof mechinism for the W108/116 series of cars? I'm trying to sort out an issue and I would like to see what it looks like before pulling things apart.
You should really start a new thread as this is a different subject. Anyways, check this site. It has a doc on sunroof.Star Motors, 1694 Union Center Maine Highway, Endicott, NY 13760, 607.786.3918 - Services - Mercedes Benz Dealer - 300sel - 450sel Good luck.
    Can you without problems change the V-class air suspension to spring suspension? kimberly V-Class 6 03-22-2017 06:10 PM
    Compressed air is leaking from the bottom of my front right strut (not from top seal) lyoooha W220 S-Class 13 03-23-2015 05:14 AM
    Leaking Air Suspension Drier Aladoro V-Class 2 01-11-2010 03:42 AM
    '06 R350 Front Air Strut Leaking... clscruizer350 W251 R-Class 0 06-25-2009 10:32 PM
    64 300 SE Front Air Suspension Valve markus765 Vintage Mercedes-Benz 4 04-12-2007 09:36 AM
