w108 sunroof doesn't fully close - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-29-2010, 04:49 AM Thread Starter
ktmripper's Avatar
Date registered: Jun 2010
Hey every one. I have had this issue since purchase. My sunroof on the w108 opens and closes ok, but when it comes to the fully closed position the rear of the sunroof doesn't pop up into place. It seals out water and air, but does not look correct. What do I adjust guides/stop/spring?
One more question, What is involved in greasing the cable. I have heard mention of it, but not seen any how to's or step by step directions
Thanks for any help or suggestions.
ktmripper is offline
post #2 of 2 (permalink) Old 12-29-2010, 09:50 AM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 37 Post(s)
Does sunroof motor continue to run if you hold switch in closing position?
To get batter look at things and clean and lube remove liner. Open sunroof about half way, using plastic wedge carefully unclip 6 clips at leading edge and pull forward and out trough opening.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
    Sunroof Won't Close - How do you reset the sunroof? Tri-Star W203 C-Class 23 09-14-2016 01:39 PM
    Tailgate won't fully Close kevintj1s W251 R-Class 7 08-13-2010 11:39 PM
    Help! My hood does not close fully Duggy72 W126 S,SE,SEC,SEL,SD,SDL Class 8 02-28-2010 07:16 PM
    Top doesn't fully close or open? spilok R230 SL-Class 6 01-30-2009 04:44 PM
    W126 Sunroof Not Closing Fully BenzSDL W126 S,SE,SEC,SEL,SD,SDL Class 7 05-16-2006 07:27 PM
