Fintail power steering problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-22-2010, 01:01 PM Thread Starter
Date registered: Dec 2010
I have a '66 230s fintail power steering works fine in one direction and no assistance other direction also throws out the p/s fluid when turning in the non assisted side. Seems like a valve blocked? Anyone familiar with these? Car has been in storage.
pmpg9 is offline
post #2 of 3 (permalink) Old 12-22-2010, 07:40 PM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
If you had to add PS fluid, you need to bleed it, which will take a couple or people. Look at the top of the steering gear and you will see what looks like a brake bleed screw. Get a stiff piece of plastic tubing and route it from the bleed screw to the reservoir. Start the car, add fluid, move the steering wheel from side to side and open the bleed screw. The air will be ejected and when there is no more air, close the bleed screw. Check for leaks. (actually, check for leaks first and fix any first).
wbain is offline
post #3 of 3 (permalink) Old 12-23-2010, 07:21 AM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
Had a similar problem with mine:
http://www.benzworld.org/forums/vint...ring-gear.html
Bled it and it works great still, never looked for a leak, but I imagine the guy before me was changing all the fluids (which is a good thing) and didn't know there was a bleeder.
tgikal is offline
Power steering problem? ra6hc W163 M-Class 3 07-14-2010 02:24 PM
Power steering problem c5vette W163 M-Class 14 06-22-2010 06:54 PM
Power steering problem, or is it simonbe W202 C-Class 3 10-11-2009 12:17 PM
Problem with power steering dore_ionescu General Mercedes-Benz 2 06-14-2009 10:02 AM
Power steering problem Vicky G-Class 7 07-28-2003 06:48 AM
