1971 220D idle surge - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-22-2010, 12:54 AM Thread Starter
Date registered: Dec 2010
Vehicle: 1971 220D
My high mileage 71 220D surges at idle when cold (idles fast then slow) & will smooth out when warm but the surge will carry to a higher rpm once warm. (about 1400 rpm) There is no surge once the motor is under a loaded condition. Has anyone experienced this or have any ideas as to what it could be? The car runs fine otherwise, not the fastest thing in the world but guaranteed to get you there. Gas mileage is 24mpg. I've cleaned/adjusted throttle cable, linkage, intake & choke all to no avail. Any help is appreciated, Thanks.
rather_b_boatin is offline
post #2 of 4 (permalink) Old 12-22-2010, 01:13 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
The vacuum chamber of the governor of the pump is leaky. This will cause this sawing of the engine. Leaks can occur because of:
- leaky diaphragm
- leak around the axle of the poppet cam
- leak of the connection of the vacuum tube
- leak of the gasket between poppet and governor housing
Usually it is the axle, but a diaphragm is also possible.
Read about the working of the governor in the FSM:
07.1 Diesel Injection System - OM616
there 07-010 section A
Govert70227 is offline
post #3 of 4 (permalink) Old 12-23-2010, 03:28 PM Thread Starter
Vehicle: 1971 220D
Thanks Govert. It looks like I can get a re-build kit for around $35us. Is this a hard/skilled job? I've re-built many carburators in my time just never a diesel component.
post #4 of 4 (permalink) Old 12-23-2010, 09:57 PM
Quoted: 4 Post(s)
Replacing the poppet cam house (picture below, 15 is the poppet cam) is easy enough, just use a new gasket and watch for stuff falling out.
Replacing the diaphragm is more complicated, you need a micrometer and it is difficult to connect the diaphragm to the control rod of the pump.
FS: 1971 220D + Parts and Manuals dbgholdings For Sale/Wanted/Trade/Giveaway 2 12-22-2010 05:52 AM
1971 220D does not engage greasekat Vintage Mercedes-Benz 10 03-23-2010 12:24 PM
new member 1971 220d JELLYBEAN220D Vintage Mercedes-Benz 0 09-08-2008 02:38 PM
1971 220d workinmandan2936 Vintage Mercedes-Benz 2 01-30-2007 11:19 AM
1971 220D for sale - Atlanta GA katydid For Sale/Wanted/Trade/Giveaway 2 01-07-2007 02:20 PM
