73' 350SL Cold Idle Surge - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-19-2010, 09:31 PM Thread Starter
Date registered: Dec 2010
I have a 73' 350SL (3.5 gray market) that has always surged at idle cold, then smooth warm. Aux. air valve is functioning creating high idle, then it lopes or surges like its lean. Checked coolant sensor - ok. Don't know what else it can be. Help
hpranch is offline
post #2 of 3 (permalink) Old 12-19-2010, 11:32 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
I had the same issue with my 4.5. I replaced all the vacuum lines and solved the issue... Those plastic lines are available at a local parts store. If you go down this route, be sure to replace the rubber connector bits as well. They often crack with age.
Grubeguy is offline
post #3 of 3 (permalink) Old 12-20-2010, 06:48 PM
unimoged's Avatar
Date registered: Dec 2008
Vehicle: 2004 S500. 2000 CLK430 Cab, 1999 C43 AMG. 1999 S500. 1999 S320. 1977 230 4 spd, 1972 280SEL 4.5
Also, make sure that the throttle position sensor is functioning properly. You should be able to hear it click when the throttle is released from a very slight opening.
unimoged is offline
    74 450sl cold idle surge wvbenz R/C107 SL/SLC Class 5 09-30-2010 04:42 PM
    cold start surge hoot8mon W211 E-Class 0 02-20-2008 10:15 AM
    Idle surge Fernandez W124 E,CE,D,TD Class 22 09-04-2007 09:00 AM
    Idle surge !!! Leester R129 SL-Class 2 04-06-2007 09:33 PM
    throttle surge when cold? baudenfj General Mercedes-Benz 3 12-16-2005 09:41 PM
