1972 220d - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 12-07-2010, 06:04 PM Thread Starter
b3lrod's Avatar
Date registered: Dec 2010
okay that makes a lot more sense now. thank you.
if that system keeps the engine from turning too fast, could i put the car in neutral and slowly depress the accelerator until the engine note stops rising? that seems like it would give me a good guess as to where i need to shift...
b3lrod is offline
post #12 of 14 (permalink) Old 12-08-2010, 01:11 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
No, if you fully press the accelerator pedal with the transmission in neutral, the engine will rev to the highest speed unloaded, it wouldn't give you any indication on when to shift.
The tests I described are to determine whether the accelerator pedal fully opens the throttle and whether the throttle opens wide enough, because if not, the car will be slower than it should be.
I drive a similarly powered car (the 1980 200D, has the same horsepower but slightly lower torque) and in city driving I shift at around 2000-2500 rpm. That corresponds with the following shift points:
1 > 2 at 10 mph
2 > 3 at 20 mph
3 > 4 at 32 mph
When I'm accelerating to get onto the highway, I may shift at 50 mph from 3 > 4
Govert70227 is offline
post #13 of 14 (permalink) Old 12-07-2011, 07:06 PM
Date registered: Jun 2009
Vehicle: 1981 240D, 1981 280e, 1982 240D, 1982 280SL, 1990 300SEL
I know this post died along time ago but I was wondering how you would be able to tell if the throttle was opening enough? I have a 1981 five speed 240D but the odometer has been disconnected for a very long time. I'm having problems getting my car up to speed sometimes. I've checked all the obvious like the linkages and the fuel filters so I'm not sure those would be the problem. I've checked a lot of other things that might be causing the car to accelerate slower than usual but I haven't run across anything obvious...
calogero05 is offline
post #14 of 14 (permalink) Old 12-09-2011, 04:30 AM
Quoted: 4 Post(s)
The 1981 240D doesn't have a pneumatic governor, so there is no throttle. The 1982 240D does have a throttle for the EGR, but I don't think there is one on the 1981 model. If that is stuck, it can have an effect on performance. It is easily checked, there must be linkage from the valve cover to the intake manifold and the throttle is visible if you remove the air filter housing.
Have you checked the tank fuel filter? Checked all the fuel supply lines for possible air leaks?
The 1981 240D is a W123, that model has a specialised forum:
W123 E,CE,D,CD,TD,TE Class - Benzworld.org - Mercedes-Benz Discussion Forum
1972 220d Shifter Bushing GGCO Vintage Mercedes-Benz 2 08-13-2009 11:55 PM
1972 220d smoker marvin9679 Vintage Mercedes-Benz 1 05-21-2009 06:04 AM
Newby - 1972 220d - won't start marvin9679 General Mercedes-Benz 4 04-23-2009 03:30 PM
parting out 1972 220d joelmopar For Sale/Wanted/Trade/Giveaway 1 04-14-2008 10:15 AM
WTB M-B 220D parts (reasonable) - 1972 mjlehner For Sale/Wanted/Trade/Giveaway 1 01-13-2006 10:06 PM
