1976 300D door problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-02-2010, 07:33 PM Thread Starter
Date registered: Dec 2009
Vehicle: 1976 300D
Quoted: 2 Post(s)
Send a message via Yahoo to amarbenj
i have manual doors..they do not close perfectly...please give me tips to fix it..thanks..
amarbenj is offline
post #2 of 2 (permalink) Old 12-13-2010, 09:09 PM
Date registered: Nov 2006
If the problem is with latching, then get a big #4 phillips on the end of your ratchet and adjust the latch. Put some white grease on the spindle and close. Then open and see where the latch is closing. The idea is to adjust it to close centered. But before that, you need to adjust the door in the body opening so that it is equal clearance all around.
open the door and heave up and down on it. Is there vertical play? If so the door pins are worn and need replacing. They are available from MB. Get some brass shim material from the hardware store (comes in different thickness) Make a shim, leaving slots for where it will slip under the bolts. Try different thickness of shims until you get it to fit correctly and evenly all around. The driver door is usually more worn than the others. Look at the back doors to get an idea of how smoothly things should fit and look. This is pretty standard body work stuff., Consult any good body shop text for more details. And happy motoring, these are great cars and will run forever if you keep them greased and aligned and tuned up
Marshall in Phoenix
DrSparkey is offline
    FS 1976 300D - 4 door sedan jbenoit For Sale/Wanted/Trade/Giveaway 4 11-16-2010 12:23 PM
    1976 300D, oil pan problem amarbenj Vintage Mercedes-Benz 2 10-21-2010 06:46 AM
    1976 300D Door problem amarbenj Vintage Mercedes-Benz 0 10-18-2010 12:12 AM
    1976 300D -problem installing hub caps camcbrat W123 E,CE,D,CD,TD,TE Class 4 06-18-2009 07:33 AM
    1976 300D Trunk and Door locks switch wont work eageclaw W123 E,CE,D,CD,TD,TE Class 3 11-23-2005 06:18 AM
