1976 300D intermittent starting issue, ignition switch? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-29-2010, 10:24 AM Thread Starter
Date registered: Oct 2010
Sometimes it starts perfectly, instantly. Other times when I turn the key to the start position nothing happens. If I keep trying it eventually engages the starter and it starts up. My first thought is the ignition switch. Anything else I should check before ordering the part? Is the ignition switch fairly easy to replace? Any advice is greatly appreciated. This is my first post, so thank you in advance to anyone that can help a newcomer like me.
Cheers,
Jon
Surrey, BC Canada
Moozak is offline
post #2 of 2 (permalink) Old 10-29-2010, 06:58 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Is it an automatic? If so, there is the start inhibitor switch on the transmission which can cause trouble. Try starting it in N instead of P. An other possibility is the starter solenoid which can be stuck. The ignition switch is probably the last thing.
For a 1976-W123-300D there is also a dedicated Benzworld forum:
W123 E,CE,D,CD,TD,TE Class - Benzworld.org - Mercedes-Benz Discussion Forum
Govert70227 is offline
Intermittent starting issue vitao R129 SL-Class 28 03-07-2011 07:33 AM
1976 300D-ignition key off, engine won't stop amarbenj Vintage Mercedes-Benz 2 10-12-2010 09:33 PM
Starting Problem - Ignition Switch Location hcsodh W140 S-Class 12 03-24-2010 03:59 PM
300SD - intermittent starting issue when car is warm TimC W126 S,SE,SEC,SEL,SD,SDL Class 8 10-04-2006 05:56 PM
1976 300D Trunk and Door locks switch wont work eageclaw W123 E,CE,D,CD,TD,TE Class 3 11-23-2005 06:18 AM
