Which power for Pertonix ignition - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-23-2010, 09:35 PM Thread Starter
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 36 Post(s)
I know there are several threads about retrofitting Pertronix onto vintage Mercedes, but I have a specific question I can not find.
I have a '72 280SEL4.5 that seems to have suffered ignition module failure. Voltage to the primary of the coil does not change when the points open. I am ordering the Pertronix 1885 module with the flamethrower coil. I am obviously replacing the MB module since it is bad.
Question is, the new Pertronix does not need the ballast resistor in series so the 12v power source can go straight to the + of the coil, but what do I do with the other power source to the existing module. There is the 12V from the ignitin switch which feeds through the resistor, and the 12V from the starter relay that supplies 12V bypassing the resistor during cranking. For those who have done this conversion, I assume youran the 12v from the switch to the coil, but what did you do with the 12V from the starter relay? Pertronix says not to leave the ballast resistor in the source.
Any other issues with the 1885 Pertronix swap I should be aware of?
Thanks
TZ_280SEL is offline
post #2 of 4 (permalink) Old 10-24-2010, 01:11 AM
Date registered: Jun 2010
Vehicle: 1966 MB 200; Porsche 914 (6); Porsche 914 (Chev 350); 36 ford
Quoted: 19 Post(s)
Make sure you are using the correct coil for your ignitor. If I remember, the series I ignitor requires the 3 ohm coil Check to be sure, don't trust my memory.
-- brett
bfrymire is offline
post #3 of 4 (permalink) Old 10-27-2010, 07:37 PM Thread Starter
TZ_280SEL's Avatar
Quoted: 36 Post(s)
Got my new ignition today in the mail. Took a bit longer to install (about an hour total) because the leads supplied with the pertronix were too short to reach the coil so with a bit of splice, heat shrink and some wire loom, all was in place. The Pertronix installation says to use the 1.5ohm coil with V-8s without a ballast resistor. I have completely removed the MB black box and all ballast resistors. I am using the 12V supply from the ignition switch as power to the + of the coil as well as the Pertronix. Other Pertonix lead to the - side of the coil. Taped up the other 12V supply from the starter relay as it is no longer needed.
She fired up on the first crank. idles great and has more power. I did have to adjust the idle way down because it was very high. I think the old girl was struggling to stay running for a while with the old ignition.
Thanks for the help.
post #4 of 4 (permalink) Old 10-28-2010, 01:31 PM
Date registered: Oct 2010
Ign mod
Good to hear it worked out well. I used the adapter sold by Hot Spark. As far as your ignigtion module and resistor, take it out, put it on ebay or trash it you dont have to worry about it again
curtisl is offline
    no power to ignition starter relay jmj200e W124 E,CE,D,TD Class 5 01-15-2013 06:30 AM
    Tapping into ignition power Samsonite Audio & Telematics Forum 2 01-18-2010 04:49 PM
    tapping ignition power Samsonite W203 C-Class 1 01-13-2010 09:28 PM
    SatNav still drains power while ignition is off? keyhole C209/A209 CLK-Class 4 03-19-2008 02:58 PM
    Power seats without key in ignition ghitos73 W163 M-Class 4 03-08-2003 11:27 PM
