Heater Control Valve 78 450 SL - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-19-2010, 08:22 AM Thread Starter
Date registered: Oct 2010
Vehicle: 1978 450 SL
I'm looking for a solution to fixing the heater control valve housing unit for my '78 450 sl that doesn't involve paying $1500 for a new unit. I've recently purchased the car and am a newbie when it comes to this type of car. Any suggestions?
hux is offline
post #2 of 3 (permalink) Old 10-19-2010, 06:43 PM
Date registered: Apr 2007
Vehicle: 1999 E320, 1975 450SEL, 1979 280SE
Quoted: 8 Post(s)
If your car has the automatic climate control that was a Chrysler design, then your problem is common. A solution is to bypass the control housing with a seperate valve, controlled by installing a cable with a pull knob below the dash. I have this set up in my 1979 280SE (w116). It works well. It's inexpensive and fairly easy to install. When you want heat, you just pull the knob and the hot water flows through the heater core. The fan should work normally. The A/C works as usual. Basically, you would be converting the automatic system to a manual system. Hope this helps!
rabbit188 is offline
post #3 of 3 (permalink) Old 10-19-2010, 10:01 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Mercedes R107 Climate Control Parts
GeeS is offline
    Location of Heater Control Valve DerDeutsche W201 190-Class 4 07-20-2013 06:52 AM
    heater control dvo valve philip29 W140 S-Class 3 10-14-2009 03:39 PM
    Manual heater control valve erod84 W201 190-Class 0 03-30-2008 01:11 PM
    Wiper heater control valve Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 01-08-2002 02:37 AM
    Heater Control Valve Guest (MBNZ) W201 190-Class 1 05-30-2001 11:18 AM
