need help on 72 4.5l v8 not starting! - Mercedes-Benz Forum
post #1 of 28 (permalink) Old 10-16-2010, 11:54 AM Thread Starter
280se_marshall's Avatar
Date registered: Aug 2010
Vehicle: 1972 280SE 4.5
hey everyone im having problems starting my 1972 280se its the 4.5l v8.
i purchased the car about 2 months ago an had no prior problems with it running or anything. all of a sudden about a week ago i drove to the store to get some food then when i came out and tried to start my car nothing happened. When i put the key in the ignition and crank it to turn on nothing happens. all the electrical works such as lights, radio. but when i go to turn the key nothing happens, when u turn the key you don't here the sound of the starter clicking. so long story short, I got the car back to my house and now that's where it sits. so THEN I starting doing some homework and thought it would be my solenoid so i replaced that and still nothing happens when im inside turning the key... BUT I can jump the car by putting the those wires together under the wiper fluid reservoir and starts up and runs no problem! Its Like nothings wrong with it at all Idles great like before this problem! what the hell is wrong with my car! I also already check fuses all are good, could it be a ground or bad wiring?? idk, but much help is needed i feel it could be something simple but not sure since this is my first Mercedes. Any advice would be helpful! Im trying to get my mercerdes back on the road again.
280se_marshall is offline
post #2 of 28 (permalink) Old 10-17-2010, 05:11 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
The ground strap from the engine to the frame is located at the right rear of the engine. It's hard to see from the top. If you can get it on a rack, get it up and have a look. They can get dirty and gummed up with oil and road grit. That's my guess. Good luck!
Ed Mclass is offline
post #3 of 28 (permalink) Old 10-17-2010, 11:55 AM Thread Starter
ok so you think it might be a ground? does that ground strap go to the firewall when im underneath it? I will check that out asap. Also I noticed that the break and generator light stays lit on my cluster without the keys in it!?? it never use to do that. Im starting to think its a short or open circuit?? maybe ignition.. not sure
Thanks for the help
post #4 of 28 (permalink) Old 10-17-2010, 03:45 PM Thread Starter
from working on it today I noticed that the battery holds charge to the car and never goes off! i have constant power to the car at all time even when the key is not in!! this is not good! it never use to do that before. When I take the key out the ignition, the car will still run totally fine, the steering wheel still locks though when u move it without the key! could it maybe ignition problem? she starts up right away when I jump the starter wires with a needle nose! grounds check out so far!
post #5 of 28 (permalink) Old 10-18-2010, 09:11 PM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
Sounds like you need to start looking at the ignition switch (where the key goes) as the problem...
tgikal is offline
post #6 of 28 (permalink) Old 10-19-2010, 04:17 PM Thread Starter
ohh okay i will try and take off the ignition key, im thinking its the ignition switch that i may need to replace but im not to sure yet, or even how to go about doing that. but sooner or later i will figure this out!
post #7 of 28 (permalink) Old 10-20-2010, 11:33 AM
Date registered: Apr 2010
Vehicle: 1972 280SE 4.5 "Kenyatta" , 1972 280SE 4.5 "Arabian Gray"
Another possibility is that you are not fully in Park. It took me ages to figure it out and how I found out is that I put the car in Neutral and tried cranking and it started right up. My transmission bushings are shot, don't know about yours...
Sam.
505t is offline
post #8 of 28 (permalink) Old 10-27-2010, 08:21 PM Thread Starter
finally got time to work on her and i got pretty far but I could not figure out how to take off the ignition? got everything else off but that. IM a noob so can anyone give me some advice i dont want to break anything or have to pay someone to get it off, hers a pic of the progress.
post #9 of 28 (permalink) Old 10-27-2010, 08:23 PM Thread Starter
The ignition switch looked fine i could not see anything wrong with it some i think its my ignition it self is bad? trying to take it out so i can replace it! I cant drive my car untill i get it out cus i cant turn it off with the key!!
post #10 of 28 (permalink) Old 10-27-2010, 08:33 PM Thread Starter
i liked this pic with summer tires
Still not starting!? hellah fresh W140 S-Class 44 03-29-2010 03:41 PM
Starting cold - starting hot?? rob2218 R/C107 SL/SLC Class 13 09-06-2008 07:48 PM
Starting over..... FishWagon W126 S,SE,SEC,SEL,SD,SDL Class 5 05-28-2005 04:52 AM
Starting Problem (Back window rolls down when starting up the car) fastneutron W202 C36 AMG, C43 AMG 3 08-08-2004 10:23 AM
anyone have starting problems? My car died twice today after starting... cgeorge430 W163 M-Class 10 08-03-2002 10:57 PM
