need help on 72 4.5l v8 not starting! - Page 3 - Mercedes-Benz Forum
post #21 of 28 (permalink) Old 11-16-2010, 10:22 AM Thread Starter
280se_marshall's Avatar
Date registered: Aug 2010
Vehicle: 1972 280SE 4.5
also it starts in park now when i jump the starter fires right up first time, every time.. but dont want to have to get out of my car every time and jump her with a needle nose, rather stay warm inside and do it with the key ya know.
280se_marshall is offline
post #22 of 28 (permalink) Old 11-22-2010, 11:33 AM Thread Starter
anyone have anymore suggestions for me to try?
post #23 of 28 (permalink) Old 11-27-2010, 06:02 PM Thread Starter
replaced starter relay switch didnt work either bummers
post #24 of 28 (permalink) Old 11-27-2010, 06:05 PM Thread Starter
i also took of distributor cap and tried to clean it just in case there was corrosion or water in it, after cleaning i started up the car and it ran different, slow and not so responsive.. not good things have been constantly going down hill with this car. time to get new plugs cap and rotor haha. Im going to check the connection from the relay to the starter tomorrow hope its a corroded wire. The VI is the violet wire and that runs from the starter to the relay, checking that for a short and go from there.
post #25 of 28 (permalink) Old 11-27-2010, 11:08 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Yes - your ignition switch. Have you considered that everything you're replacing might have cost you more than replacing the ignition switch at the outset?
Grubeguy is offline
post #26 of 28 (permalink) Old 11-28-2010, 11:13 AM Thread Starter
yah i do realize this but i still have not really even figured out the original problem yet, although now i know i have replaced everything except the ignition switch it seems like, haha. if it is the ignition switch we can only hope. thanks for the advice i will pull the ignition switch
post #27 of 28 (permalink) Old 12-02-2010, 07:55 PM Thread Starter
Pulled the switch today. it took me forever to get those 3 screws on the male end of the switch off the ignition. Once I finally got the male part of the switch out, I noticed the end the goes into the ignition had metal peices all inside of it. I think when I went to turn the ignition the end peices broke of the ignition broke off inside of the switch itself. I got a new male switch but it looks to me the end of the ignition itself broke off.. Bummers. Trying to take off ignition tomorrow. I got one bolt out and ran out of light, ignition is really lose now but cant figure out how to pull it off the steering column.. Any one know how to do this?!? Marsh
post #28 of 28 (permalink) Old 01-01-2011, 02:02 PM Thread Starter
i figured it out, replaced ignition now car is fixed = ) but for some reason it wont stay in park! it goes into reverse and also drive but no park for some reason i know cus i live on a hill.. so im going to take cluster back out and see if i didnt hook something up wrong. problem solved for the most part now cost me all of $35 for a new ignition.
    Still not starting!? hellah fresh W140 S-Class 44 03-29-2010 04:41 PM
    Starting cold - starting hot?? rob2218 R/C107 SL/SLC Class 13 09-06-2008 08:48 PM
    Starting over..... FishWagon W126 S,SE,SEC,SEL,SD,SDL Class 5 05-28-2005 05:52 AM
    Starting Problem (Back window rolls down when starting up the car) fastneutron W202 C36 AMG, C43 AMG 3 08-08-2004 11:23 AM
    anyone have starting problems? My car died twice today after starting... cgeorge430 W163 M-Class 10 08-03-2002 11:57 PM
