74 230 need helpfor ignition - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-16-2010, 11:57 AM Thread Starter
Date registered: Oct 2010
Vehicle: 1974 Mercedes Benz 230
Question 74 230 need helpfor ignition
I recently purchase a 74 230 from a friend of mine for about $200 in trade. He told me gas lines where rusted out but they ended up fine, just needed new rubber hose fitting. he has a lot of surface rust but interior fairly intake. Only thing its missing off body is back passenger side hubcap. I am in school for body work and refinishing so that is no big deal. The problem is when i turn the key the starter does not turn over. I've replaced all fuses under the hood with eurpean style like he had in it. ive jumped cylinoid on starter and it turns. its getting power because lights come on and hazards. Wipers work and so does brake lights. Radio does not come on with key turned and neither does AC unit (factory) and horn not really. If key is in and door opens it does buzz. Anyone give me an idea of this problem. This is my first mercedes and would love to have it running within a month of owning it. Then just gotta focus on the body work. Thanks for reading. Griz
Grizzly53 is offline
post #2 of 5 (permalink) Old 10-16-2010, 05:38 PM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 107 Post(s)
Automatic or standard?
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #3 of 5 (permalink) Old 10-17-2010, 04:43 AM Thread Starter
automatic
post #4 of 5 (permalink) Old 10-17-2010, 08:37 AM
Witek_M's Avatar
Quoted: 107 Post(s)
Power flows to starter solenoid from battery>headlight switch>ignition switch>neutral safety switch (contacts closed in P and N)>starter. Wire is violet, violet/white. Using test light find out where the brake is.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #5 of 5 (permalink) Old 10-17-2010, 09:14 AM Thread Starter
i think the neutral safety switch is it. the wiring harness has a wire that breaks away from harness thats black (ground right? or something else?) thats just hanging there.
    Ignition Switch Wiring 1992 Mercedes 230 pkeohane General Mercedes-Benz 3 11-01-2010 05:24 AM
    Ignition wiring diagram and ignition barrel install rtn W123 E,CE,D,CD,TD,TE Class 1 10-05-2010 09:28 PM
    Link between ignition coil & ignition lock - S600 zambussi W220 S-Class 0 08-03-2010 10:53 AM
    99' ML430 TOPIC: Ignition Misfire unknown if coil or ignition wires??? luebes General Mercedes-Benz 4 09-23-2008 06:19 PM
    how much faster is the slk 320 vs the 230? 0-60? 1/4? is the 98 230 slower than say a 2001 230? RaVEr R170 SLK-Class 12 04-09-2002 04:27 PM
