65 220SEb CABRIOLET: WHAT ARE "CLEARANCE LIGHTS"? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-13-2010, 10:18 PM Thread Starter
Date registered: May 2004
Vehicle: 1965 220SEb Cabriolet, 1994 E320 Cabriolet, 1999 ML320
While changing bulbs in my W111 Cabriolet I found that there are two small 4W bulbs in tandem in the center of the tail/brake/turn-signal light cluster. The front one is the tail light and the one behind it is described in the owner's manual as the "clearance light". I could not get it to light up and have no idea of what it's purpose is. Does anyone know? Thanks!
Marvin Huey
Lawrence, Kansas
1965 220SEb Cabriolet, !994 E320 Cabriolet, 1999 ML 320, 1965 BMW R60 motorcycle w/ Steib sidecar
ketchsailor27 is offline
post #2 of 3 (permalink) Old 10-14-2010, 04:53 AM
Date registered: Jun 2010
Vehicle: 2013 E350 Sport 4Matic
They are "Parking lights" in German
I suspect those are what the Germans refer to as "Parklicht." If you turn your light switch counter-clockwise one stop the right rear lights and two stops the left rear illuminates. It was designed for parking on dark un-lit roads and avoiding someone running in to you.
Old Benz Fan
(Dreamt about W108/109 for 37 years and finally got one!!)
1967 300SEL - White on blue velour
oldbenzfan is offline
post #3 of 3 (permalink) Old 10-14-2010, 10:44 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 118 Post(s)
I have a slightly different answer. Clearance lights are lights to be left on when parked on the side of the road. If you turn the light switch one click to the left you activate the left clearance lights (front and rear). If you turn the light switch 2 clicks to the left you instead activate the right clearance lights (front and rear). (I may have left and right mixed up, but you get the idea). This is a common function on Mercedes cars from at least the 1960s and possibly earlier and continues past 2000, assumedly to present.
Some US cars do not have clearance lights enabled (same with rear fog light). In some cars, enabling them involves putting a bulb in the socket that is missing the bulb. In other cars, wiring and the addition of bulb sockets is necessary. Regardless, there are lots of Mercedes light fixtures (or Euro headlamp assemblies) that are setup for clearance lights.
On all of my cars, it is front and rear, not just rear.
Scoot is offline
    Dash "Brake" and "Seatbelt" lights. Need help. cubefx W123 E,CE,D,CD,TD,TE Class 7 06-16-2010 04:51 AM
    WTB "WIS" 1995 E320 Cabriolet DReisbord For Sale/Wanted/Trade/Giveaway 0 12-16-2009 07:48 AM
    End of summer "Clearance Sale" on used mog parts! VON Unimog 7 10-07-2009 08:25 PM
    "Euro" 1961 220SEb ? NutmegCT Vintage Mercedes-Benz 1 02-17-2009 05:56 PM
