1976 450 SLC sat for 3 years, cant get it to run - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 10-06-2010, 09:41 PM Thread Starter
Date registered: Sep 2010
Vehicle: 1976 450 SLC
I inherited this car, so far I have nicknamed it "the money pit."
As I shift my meager wealth to the local mechanic, I continue to long to see this vintage gem hum along the mountain pass with me behind the wheel.
I used a matrix that I found on this site for steps to follow when a car has sat for a couple of years.
So far I have had the old gas removed, the tank cleaned and as a result
I apparently needed a new fuel pump and a few minor hoses.
Took the spark plugs out and put a little in a little oil.
Fuel supply lines ok now, Gas Distributor ok, fuel injectors ok. new battery
Car turns over but will not sustain an idle.
Currently I am told that I need a "Warm Up Regulator" and that I need to get the correct original part number. Any suggestions, Where do I go to find this out?
jetskimom is offline
post #2 of 7 (permalink) Old 05-29-2011, 07:42 PM
~BANNED~
Date registered: May 2011
Vehicle: SL500 '93 SL500 '02 SILVER ARROW, E320 WAGON '94
Send a message via Skype™ to LCAN
THE FUNDAMENTALS OF ENGINE OPERATION -
IT NEEDS AIR
IT NEEDS FUEL
IT NEEDS COMPRESSION
AND IT NEEDS A SOURCE OF IGNITION AND IMPORTANTLY AT THE CORRECT TIME. (TIMING)
CHECK YOUR AIR CLEANER AND INTAKE SYSTEM FOR RESTRICTIONS EG: (RAG, DEBRIS, RAT NEST) JUST REMOVE THE AIR CLEANER FOR NOW AND CONTINUE WITH YOUR DIAGNOSIS
CHECK IF YOU HAVE SPARK = NO - CHECK WIRES, PRIMARY, SECONDARY , DIST CAP, & DISTRIBUTOR . YES -
CHECK IF YOU HAVE FUEL AND THE QUALITY OF FUEL.
FINALLY CHECK THE COMPRESSION OF EACH CYLINDER.
I AM ASSUMING THIS VEHICLE HAS A CARB. NEVER THE LESS ALL OF THE ABOVE APPLY TO THE INTERNAL COMBUSTION ENGINE. IF ANY OF THE ABOVE ARE FOUND FAULTY - STICK TO THE PLAN AND STAY WITH THE SYSTEM THAT IS CAUSUING THE PROBLEM. OR YOU WILL SOON FIND OUT SOONER OR LATER THAT EVERY DIME YOU HAD IS IN THE POCKETS OF SOME HAY WIRE MECHANIC.
LCAN is offline
post #3 of 7 (permalink) Old 05-29-2011, 09:02 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 665 Post(s)
Warm-up Regulator: Mercedes R107 Fuel System Parts
GeeS is offline
post #4 of 7 (permalink) Old 05-29-2011, 09:43 PM
~BANNED~
IT WAS MY UNDERESTANDING YOU HAD INSTALLED THIS COMPONENT ALLREWADY ????.
LCAN is offline
post #5 of 7 (permalink) Old 05-30-2011, 09:38 PM
Angel76's Avatar
Date registered: Apr 2011
Vehicle: 1976 450 SE
I feel your pain. Keep up the good work. Another '76 on the road is worth it!!
Angel76 is offline
post #6 of 7 (permalink) Old 05-30-2011, 11:34 PM
Date registered: Mar 2011
Vehicle: 1971 250/8 sedan with 80 K miles. Driven only in Summer.
I was battling a similar problem with my 250/8. a twinn carb engine. Rebuild the carbs twice, new fuel pump,new plugs, new gas .You name it I tried it. The car started out beautifully but once the chokes opened up, the blasted thing died on me . As a last try I disconected the two regulator ( pulled the plugs out) and low and behold ,the engine kept on running. they are both operated by the carb's vacuum. Uninstalled both of them, put some WD40 inside, blew them out and put everything back. There is light at the end of that tunnel. Good luck.
Over 75 is offline
post #7 of 7 (permalink) Old 06-04-2011, 10:18 AM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
You might want to slide over to the 107 forum. There is a lot of info there, and a lot of people that are willing to help. Check out the EGv107 sticky at the top of the forum first, to save yourself some time.
RadioTek is offline
    1976 vs 1979 450 SLC javadude R/C107 SL/SLC Class 15 12-05-2009 12:29 AM
    1976 450 SLC Catalytic Converter javadude R/C107 SL/SLC Class 3 11-12-2009 12:42 PM
    I am thinking of getting a 1976 450 SLC DP Off-Topic 99 11-12-2009 06:35 AM
    1976 450 sl won't run...... squirrel_master R/C107 SL/SLC Class 2 09-24-2006 10:32 PM
    whether or not to get for free a 1976 450 slc chaos R/C107 SL/SLC Class 5 10-02-2005 10:32 AM
