First Mercedes, electrical trouble. - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-30-2010, 02:09 PM Thread Starter
Date registered: Sep 2010
Vehicle: 72 250c
First off, hello out there! I've been visiting this site for the past month and have found it to be a great source of information, however a problem has been confounding me with a 72 250c. Its in a fairly bad state of repair, but due to it being a gift. I've been slowly trying to get it running. The engine cranks perfectly fine, but there is no spark.
In trying to repair the problem, I've replaced a cracked distributor cap, adjusted some wiring, timed the spark wires, replacing them with new wires. There was two coils in the vehicle at the time of purchase, and I have installed one of the coils that seems fine in my tests. I have also replaced all the fuses, which also lead to the same result.
I do not trust the wiring job that is currently in place, but having no electrical diagrams has been a problem. The lighting is perfectly fine, and when the car is turned over, the lights dim, making me assume it isn't a problem with the ignition switch.
I'd be a great help for any advice on the situation, I can provide pictures of whatever is required. I really hope to get this 250c back on the road. It doesn't deserve to keep rusting away in a field.
Ruler is offline
post #2 of 6 (permalink) Old 09-30-2010, 04:52 PM
Date registered: Apr 2007
Vehicle: 1999 E320, 1975 450SEL, 1979 280SE
Quoted: 8 Post(s)
Do you have a voltage tester or test light? Use a tester or meter to make sure that you are getting voltage to the coil. There are ways to jump a wire to the coil from the battery to see if the engine will start. As long as the points and condenser are good, the plugs should spark. There are plenty of web sites that can provide a wiring diagram, also. Good Luck! Let us know how it goes.
rabbit188 is offline
post #3 of 6 (permalink) Old 09-30-2010, 05:16 PM
Date registered: Jun 2010
Vehicle: '72 - 250
To rabbit188 - what are the websites that offer wiring diagrams. I also have a 72 250 with AC electrical problems. A wiring diagram would be very helpful. Thanks.
Miss Daisy is offline
post #4 of 6 (permalink) Old 10-01-2010, 03:56 AM
Dimming lights while cranking is an indicator of a weak battery thus no volts for the sparking.
Brian O
bostosh is offline
post #5 of 6 (permalink) Old 10-01-2010, 12:29 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Just for test purposes wire the coil directly to the battery bypassing all wiring in the car. This should quickly tell you if it is a wiring problem. Don't leave the coil connected for more than a minute or it may damage your coil because you are bypassing the ballast resistors and the points may be closed allowing current through the coil.
this is known as "hot wiring" a car.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #6 of 6 (permalink) Old 10-01-2010, 03:43 PM
Quoted: 8 Post(s)
You can do a search for "free Mercedes wiring diagrams" or "free Mercedes wiring schematics". Some sites are: Free Ebook, Wiring Diagram Ebook, Service Manual Ebook, Electronic Circuits, Automotive Ebook, more Free eBook Download and Free Auto Repair Question Online Mechanics Answer Questions FREE. Also, a really good site for manuals at a good price is: Mercedes Benz Manual - Mercedes Repair Manuals - Mercedes-Benz Service Manuels.
I have a wiring diagram for the 250C that I could scan and email to you. But, it does not have A/C on it. Back then, most A/C units were added by dealers, using Thermo-King units. Thus, the A/C is not shown on the factory wiring diagram. You may have luck with searching Thermo-King or Behr, depending on which unit you have. Hope this helps!
    Mercedes Fault Codes... These Will Get You Out Of Trouble......one Day ! ;) Sarge786 V-Class 52 03-21-2016 09:03 AM
    81 240D Electrical Trouble garrisonmiller W123 E,CE,D,CD,TD,TE Class 1 11-25-2009 07:14 PM
    Mercedes Battery Trouble Jason Lap General Mercedes-Benz 6 12-19-2006 04:26 PM
    202 electrical trouble shooting guide 03-g500 W202 C-Class 1 09-16-2006 04:53 AM
    CARB TROUBLE ON 1972 250 MERCEDES Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 0 07-08-2001 07:07 PM
