VIN and Chassis Numbers 280S - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-28-2010, 08:23 AM Thread Starter
Date registered: Sep 2010
I need some help identifying my car to order parts.
On my driver's door frame and on the frame under the carburators this number is stamped 108.016 - 12 - 011315 Does this mean that my chasis number is 011315?
There is a plate on the top of the radiator frame with these numbers on it
230 258 491 503
108016 12 7
0473 88312
Is the first number the car's serial number?
Thanks for the responses. I appreciate them.
copppper is offline
post #2 of 3 (permalink) Old 09-28-2010, 10:03 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Your chassis number is 108016 12 011315
108 is the model range number W108
016 is the specific model 280S
1 means right hand drive
2 means automatic
011315 is the serial number
You need the chassis number for ordering parts etc.
The plate above the radiator shows the option codes:
230 258 491 503
and the paint number:
And some other numbers including the type number 10801612
To be sure also note the engine number and transmission number, they might not be original. You can get a copy of the car datacard at the Classic Department of MB USA if you give them the chassis number.
Govert70227 is offline
post #3 of 3 (permalink) Old 09-28-2010, 01:51 PM Thread Starter
copppper is offline
    w203 TV antenna amp problem & part numbers & vin/chassis nos perdikoula888 Audio & Telematics Forum 1 09-28-2010 09:16 PM
    VIN - CHASSIS NUMBERS rowdie R/C107 SL/SLC Class 7 11-23-2009 09:40 AM
    question about 280s vin merc w126 W126 S,SE,SEC,SEL,SD,SDL Class 3 09-08-2008 04:08 PM
    Chassis Numbers? Pack W210 E-Class 14 05-06-2008 02:05 PM
    Where are the chassis numbers ?? Murray C208/A208 CLK-Class 1 05-24-2002 07:48 AM
