DOES ANYONE HAVE ALIGNMENT DATA FOR MY 1965 220SEb CABRIOLET? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-20-2010, 09:05 PM Thread Starter
Date registered: May 2004
Vehicle: 1965 220SEb Cabriolet, 1994 E320 Cabriolet, 1999 ML320
It's odd that the info is so hard to find. Can't locate it anywhere in all of my service literature. Please help before I steer into a semi or a phone pole.
Marvin Huey
Lawrence, Kansas
1965 220SEb Cabriolet, !994 E320 Cabriolet, 1999 ML 320, 1965 BMW R60 motorcycle w/ Steib sidecar
ketchsailor27 is offline
post #2 of 6 (permalink) Old 09-22-2010, 09:08 AM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
Way to be completely off topic scoregrant....
Anyway, Hopefully this is what you need... I just scanned it from my 1959-67 manual.
(Sorry the only way I could attach full size is in a pdf, if the "700-something x 800" jpeg isn't big enough)
tgikal is offline
post #3 of 6 (permalink) Old 09-23-2010, 04:33 AM
wbain's Avatar
Date registered: Dec 2003
The alignment tech will check your front end for wear. Then you will know if it can be aligned. I took my 220SEb in and the front end is badly worn, so I'll be fixing it soon.
wbain is offline
post #4 of 6 (permalink) Old 09-23-2010, 07:03 AM
Correct me if I'm wrong, but there isn't too much in the front end of these just kingpins and tie rods right?
I'm mean they have shocks not struts and no ball joints, guess you'd have to find a alignment shop that even knows what a kingpin is vs a ball joint, none of the shops around me would have a clue... That and the only thing I know about aligning a car is the tie rod adjustments.
tgikal is offline
post #5 of 6 (permalink) Old 09-23-2010, 10:01 PM
wbain's Avatar
There's a lot, the lower trunions, the upper camber adjusters, the inner pivots and seals, the caster adjustment bushings and to add more, the rear bushings. Lets not forget the idler arm. So you see, there is much more than meets the eye.
wbain is offline
post #6 of 6 (permalink) Old 09-24-2010, 06:14 AM
*sigh*... that sounds like a lot of work, luckily mine only has 60,000 mi. on it and the alignment is still good...
tgikal is offline
    Alignment Data: K-Macs Before & After Williams707 C208/A208 CLK-Class 4 06-27-2010 03:33 AM
    W107 Alignment Data DGR R/C107 SL/SLC Class 7 04-10-2009 08:31 PM
    1965 220SE 1965 220 S crashdaddio Vintage Mercedes-Benz 4 01-09-2009 09:49 PM
    220SEb 1965 rebuilt engine break in time paloaltoW111 Vintage Mercedes-Benz 2 10-28-2004 11:44 AM
    1965 220SEb photo paloaltoW111 Vintage Mercedes-Benz 0 10-20-2004 11:02 PM
