Washer Jet Diagnosis. Am I right? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-19-2010, 11:26 PM Thread Starter
Date registered: Feb 2010
Vehicle: 1968 250SE S-Class. 1988 560SEC S-Class Widebody
Quoted: 41 Post(s)
So I decided to have a look into the washer jet not working on my '68 280se.
This is what I found
1. Unscrewed the foot pump etc, switch works fine as wipers do wipe. BUT no water comes out the jet
2. Could be completely wrong but I get the impression something should be attached to the Black bladder bit
3. Looking in the engine I see 1 hose not connected to anything with a very rough cut on the end
4. I find 2 random bits of hose just sitting in the engine bay
5. I poke through a grommet in the firewall and see where it leads to in the engine bay.
6. I think I need to find some new hose and feed it through this and connect it to the bladder pump piece. (Note grommet out of focus up the back)
7. Am I right? Or completely wrong?
8. If I'm right, does anyone know where to buy new hose?
9. Any pics of how it should attach to the bladder? Is there a connector piece I am missing?
Thanks in advance
(Plus a few extra shots for the hell of it)
D&WCali is offline
post #2 of 6 (permalink) Old 09-20-2010, 12:32 AM
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Quoted: 2 Post(s)
You're right, a hose should be connected to that bladder and go through a grommet in the firewall to the fluid reservoir. New hose at the dealer is sold by the meter and shouldn't cost much.
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline
post #3 of 6 (permalink) Old 09-20-2010, 01:39 AM Thread Starter
Quoted: 41 Post(s)
Great, ill get onto ordering it tomorrow!
Do you know how it connects to the bladder? does it just poke in there or is there some plastic piece that helps connect them securely?
D&WCali is offline
post #4 of 6 (permalink) Old 09-20-2010, 01:48 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
The hose might not be the only problem. It is possible the pump is leaking and that that is the reason the hose is disconnected. Check the pump for leaks first.
Govert70227 is offline
post #5 of 6 (permalink) Old 09-20-2010, 02:26 AM Thread Starter
Quoted: 41 Post(s)
Will do, ill clean it out and fill it with water and see what happens.
I have a feeling the water tube may have been chewed through (rat?)
Hope to find time to sort this out in the coming weeks
D&WCali is offline
post #6 of 6 (permalink) Old 09-20-2010, 10:09 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Tubing is available at any autoparts store too - dealership will be expensive.
I rigged up a push button under the foot pump that activated a generic windshield water pump I bought - much better than a foot pressure activated bladder.
Grubeguy is offline
    Noise like a jet with AC on xxnonamexx W204 C-Class 2 07-20-2010 02:19 AM
    Washer jet removal likedatyall W140 S-Class 1 05-02-2010 09:45 PM
    Best you can do for your K-jet! PUMPISH W124 E,CE,D,TD Class 43 08-16-2008 11:05 AM
    Indonesian Jet crash this morning, 15 confirmed dead in jet crash Jakarta Expat Off-Topic 1 03-06-2007 06:54 PM
    K to KE-jet oliver19 R/C107 SL/SLC Class 3 01-02-2007 03:47 PM
