280S Hissing Sound When Braking - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-17-2010, 03:02 PM Thread Starter
Date registered: Sep 2010
When I apply the brakes on my '68 280S I hear a hissing sound. I'm new to the car (and to Mercedes) but I seem need to be pressing a bit too hard on the pedal.
Any help would be appreciated.
copppper is offline
post #2 of 5 (permalink) Old 09-17-2010, 07:54 PM
wbain's Avatar
Date registered: Dec 2003
There is a filter and a seal at the rear of the booster. You will have to remove the booster and the brake pedal pin, or do it from the inside of the car. It's not critical to do it now but a search of the forum might reveal the fix, or search the DIY links at the top of the forum.
wbain is offline
post #3 of 5 (permalink) Old 09-17-2010, 08:07 PM
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Quoted: 2 Post(s)
Hissing and a hard brake pedal are signs of brake booster failure. You'll have to do as wbain says to properly diagnose the problem.
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline
post #4 of 5 (permalink) Old 09-17-2010, 09:40 PM
hugedodge2000's Avatar
Date registered: Jan 2010
mine did that then I replaced the front caliper and it quit. Check for leaks throughout the brake system before pulling your booster.
hugedodge2000 is offline
post #5 of 5 (permalink) Old 09-17-2010, 09:47 PM Thread Starter
Thanks. I appreciate the replies.
copppper is offline
    Hissing sound cal45fan W163 M-Class 2 09-14-2009 07:04 AM
    hissing sound Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 10 04-16-2008 08:33 AM
    hissing sound SilverStar W126 S,SE,SEC,SEL,SD,SDL Class 11 09-19-2007 09:01 PM
    A/C hissing sound Sandro N W210 E-Class 2 11-26-2004 03:05 PM
    hissing sound AmoS500 W140 S-Class 1 07-01-2003 05:38 AM
