Where is the overflow tank? (photo) - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 09-15-2010, 12:33 AM Thread Starter
Date registered: Nov 2008
Isn't it supposed to be just to the left of the photo, mounted on the fender? What gives? I've seen a few that are like this!
audihenry is offline
post #2 of 7 (permalink) Old 09-15-2010, 01:29 AM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
There isn't one, notice the cap on the top of the radiator. An overflow tank would have the cap.
wbain is offline
post #3 of 7 (permalink) Old 09-15-2010, 02:40 AM Thread Starter
Right you are, sir!
So the rubber hose that goes from the neck of the radiator filler towards the left of the photo, does it connect to anything? What purpose does it serve? Wouldn't that prevent the system from being pressurized?
post #4 of 7 (permalink) Old 09-15-2010, 03:48 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Originally Posted by audihenry View Post
Right you are, sir!
If the radiator cap opens, because the pressure is too high, coolant will flow through the tube to the ground. This can also happen if you overfill the radiator.
Govert70227 is offline
post #5 of 7 (permalink) Old 09-15-2010, 05:20 AM Thread Starter
Thanks! So essentially it is just for overfills and emergency type situations? Is there a hole that it goes into to pour outside, straight down?
Thanks again!
post #6 of 7 (permalink) Old 09-15-2010, 07:23 AM
Quoted: 4 Post(s)
There is a hole in the neck of the radiator, above where the radiator cap seals the cooling system, the rubber line is connected on that hole. The radiator cap is spring loaded and designed to open at a certain pressure (1 or 1.2 bar). If it opens, the pressure gasses or coolant will flow through the hole and through the rubber line unto the ground.
post #7 of 7 (permalink) Old 09-15-2010, 11:38 AM Thread Starter
Thank you very much!
w123 expansion tank overflow line patricky15 W123 E,CE,D,CD,TD,TE Class 2 02-14-2010 03:03 PM
Fuel Tank Overflow everettpa1 R/C107 SL/SLC Class 4 10-27-2009 10:55 AM
Gurgling from radiator overflow tank quidam W163 M-Class 3 09-18-2007 01:46 PM
Overflow tank inquiry The Doggfather W126 S,SE,SEC,SEL,SD,SDL Class 4 07-29-2007 12:06 PM
coolent overflow tank Blu-spot Vintage Mercedes-Benz 4 01-26-2007 08:58 AM
