300SD trunk will not open - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-12-2010, 05:17 PM Thread Starter
Date registered: Aug 2009
Post 300SD trunk will not open
My 1979 300SD trunk refuses to open as of a week ago. All worked well since I got the car a year ago then last week I could not get into the trunk.
I only have the round headed key so I don't believe the trunk in locked.
The key slot is in the horizontal position will according to the manual is unlocked. The vacume lock system appears to be working a usual?
All thoughts and ideas welcome.
JB
jgbriner is offline
post #2 of 4 (permalink) Old 09-13-2010, 11:07 AM
Date registered: Mar 2009
Vehicle: W116 450 SEL 1979 W111 220S 1962
If it was just ur vacume problem. it would still have opened by the key.
idea 1:= get a locksmith who is familiar with the benz trunk lock mechanism or get some photos of the mechanism from internet & show them to the lock smith 1st.
idea 2:
the panel behind the seat is a solid plate. behind that probably sits the fuel tank. best bet if u cant manage to open it. get the spare tyre enclosure cut from the underside. open the lock. fix it & get the spare tyre bay welded back
siddiqiumar is offline
post #3 of 4 (permalink) Old 09-16-2010, 05:17 PM
Date registered: Sep 2010
I have the same problem with my 81 280 se the trunk is locked the button goes in but will not open.Do I need to drill the lock out?
The central locking is also not working.
When I do get the trunk open I will convert the central locking to electric and do away with the antiquated pnematic system.
6t9merc is offline
post #4 of 4 (permalink) Old 09-18-2010, 08:25 AM
No dont drill the lock out it will have no effect at all. U see the mechanisim is not working. Thts got nothing to do with drilling out the "keyhole" part ... which happens to be the only exposed thing you can work on. If you drill it then you'll need to but expensive new key lock part. Best option is what I have suggeted earlier in the thread. Otherwise try to Pry open the trunk by inserting a flat lever between the trunk lid and key lock plate.
    Trunk Wont Open!! center console light is showing as open deyainrdy4ds C208/A208 CLK-Class 0 06-22-2010 08:39 PM
    Can't open trunk on 93 300SD apeace W140 S-Class 1 12-03-2008 07:54 PM
    can't use key to open trunk lock on my 300sd kona4 W116 S, SE, SEL, SD Class 0 04-13-2008 11:03 PM
    Trunk won't open 1984 300SD CharlestonSC General Mercedes-Benz 4 05-23-2005 09:52 AM
    300SD , can't get trunk open ! 4amStudios W126 S,SE,SEC,SEL,SD,SDL Class 5 09-10-2004 06:20 PM
