w108 dies when I press on the brakes! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-12-2010, 12:02 PM Thread Starter
hugedodge2000's Avatar
Date registered: Jan 2010
My w108 has been dieing when I press down on the brakes. What causes this? I'm thinking the vaccum is loading down on the engine. It does it every so often with the lights off but driving at night with the lights on it does it every time. What do yal think? THANKS!!!!
hugedodge2000 is offline
post #2 of 4 (permalink) Old 09-12-2010, 12:48 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
I think the check valve between the intake manifold and brake booster isn't working anymore. This creates a air leak, so the mixture control doesn't work.
Govert70227 is offline
post #3 of 4 (permalink) Old 09-17-2010, 09:45 PM Thread Starter
think you were partly right. It did need a new check valve, i blew through each side and it had free airflow through both. It's supposed to block off through the out let side. I put a new one of those on but it is still doing the same thing. The check valve just makes it so you have pressure to brake when your engine dies. Any other suggestions? Anyone think its a vaccum problem?
post #4 of 4 (permalink) Old 09-18-2010, 07:04 AM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
The other suggestion is the booster is leaking and is most likely shot, had to replace mine to the tune of $280...
With the car off pump the brake pedal until it gets hard, hold it and start the car, if it never gets hard or fails to drop the booster is shot.
tgikal is offline
    Tony Snow dies; ex-Bush press secretary was 53 GeeS Off-Topic 22 07-13-2008 12:05 PM
    New W108 Owner...Source for W108 Door and Window Seals? LaterApex Vintage Mercedes-Benz 5 03-24-2008 12:51 PM
    Steering wheel shakes when i press brakes? prayfawind W140 S-Class 7 01-21-2007 08:56 AM
    Sterring wheel shakes when i press brakes? prayfawind General Mercedes-Benz 10 01-20-2007 06:42 AM
    Car starts then barely idles, press gas & dies?? digsand W126 S,SE,SEC,SEL,SD,SDL Class 3 03-11-2004 10:28 AM
