W108 Stuck door (locked) - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 09-10-2010, 03:50 PM Thread Starter
tecrekka's Avatar
Date registered: May 2003
Vehicle: 72 280 SEL 4.5 - 81 VW Rabbit - 85 XJS - 86 XJ6
Haven't seen anyone have this specific problem so hopefully someone has an idea here. I have a 72 280 SEL 4.5 and the drivers rear door will not come unlocked. As it appears that all the access depends on the door being open, does anyone have any suggestions or hopefully, know any trick to getting this open? Thanks in advance.
1972 280SEL 4.5 W108.068/M117 V8
tecrekka is offline
post #2 of 10 (permalink) Old 09-10-2010, 06:06 PM
teezer's Avatar
Date registered: Aug 2007
Vehicle: 1989 300ce
little more info
lock button normal ?
inside handle normal ?
outside handle push button normal ?
ex minutiae manager
teezer is offline
post #3 of 10 (permalink) Old 09-10-2010, 10:40 PM Thread Starter
tecrekka's Avatar
Sorry, more specifically, the interior lock button is down, and the outside button acts as though it is locked ie: nothing but the return tension. I can't pull the interior knob up, and I've put as much upward pressure on it as I feel comfortable before causing something internal damage or the knob itself to fail.
Pulling on the inside handle does nothing at all.
tecrekka is offline
post #4 of 10 (permalink) Old 09-11-2010, 11:30 PM
4.5_sport's Avatar
Date registered: Apr 2004
Vehicle: 1994 E320T, 1979 VW Rabbit
Send a message via MSN to 4.5_sport
I've been battling the same issue on the right rear door. I have taken the door panel off and sprayed penetrating oil all through the latch assy...
If I figure it out I'll let you know.
4.5_sport is offline
post #5 of 10 (permalink) Old 09-11-2010, 11:46 PM Thread Starter
tecrekka's Avatar
So you were able to get the panel off though? I haven't taken the arm rest or anything off, as I didn't want to try and dismantle anything before I knew what I was getting into. I was assuming, possibly correctly, that you couldn't dismantle the latch assembly without having the door open, as the surround around the mechanism has those two (?) screws in that seem to hold it in place. Again, I haven't toyed with disassembling the other side either. I don't currently have a garage, only a carport, so I don't want to get stuck with a door that doesn't stay closed!
tecrekka is offline
post #6 of 10 (permalink) Old 09-13-2010, 07:38 PM Thread Starter
tecrekka's Avatar
Oddly enough, last night my door just "started working". I was with a couple friends from school and one got to that door before I could say it doesn't unlock and it came open no problem. Has anyone ever seen "Christine"??
tecrekka is offline
post #7 of 10 (permalink) Old 11-21-2010, 10:16 PM
Date registered: Nov 2010
Vehicle: 1972 280se 4.5
I have the same problem, the rear driver door is stuck locked. The lock button is down and neither of the door latches has any effect. Any suggestions on how to remove the door to fix this? Thanks!
Tikitamde is offline
post #8 of 10 (permalink) Old 03-25-2016, 06:38 AM
Date registered: Jun 2012
Bringing this thread back from the dead.
I have the same problem, does anyone have a fix to this?
_Dirty_ is offline
post #9 of 10 (permalink) Old 03-25-2016, 10:05 AM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 49 Post(s)
I have not watched this but Kent Bergsma's videos can be helpful.
https//mercedessource.com/problems/body-and-exterior-trim/opening-stuck-doors-old-mercedes
Will
Baybear is offline
post #10 of 10 (permalink) Old 03-26-2016, 05:43 AM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 97 Post(s)
While not germane to the specific problem herein, it is prudent to note that these cars were equipped with a "child proof" feature which prevented opening of the rear doors from the inside when the dedicated mechanical latch on the rear of each door was engaged.
rumb likes this.
ejboyd5 is offline
1982 Trunk locked - stuck Gmcwilliams W123 E,CE,D,CD,TD,TE Class 1 12-07-2008 12:31 PM
New W108 Owner...Source for W108 Door and Window Seals? LaterApex Vintage Mercedes-Benz 5 03-24-2008 12:51 PM
Im locked out of my car and stuck at work caines General Mercedes-Benz 7 03-05-2008 08:51 AM
Locked doors but 1 door (driver side) is not locked d52232dole W210 E-Class 13 09-29-2007 06:06 AM
Rear Door stuck & locked 1973 280sel 4.5 ldshull Vintage Mercedes-Benz 2 07-22-2006 08:52 AM
