my first mercedes, trying to make it run!! - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 09-28-2010, 06:52 AM Thread Starter
Date registered: Aug 2010
thats some great info!!!
i found the leak it was the hose that goes to the first injector i got it fixed.
one thing i found is with the key on each glow plug gets less volts from back to front?? is this normal?
IWantATurbo is offline
post #12 of 12 (permalink) Old 09-28-2010, 12:21 PM
Date registered: Sep 2010
Vehicle: W124 e220, W124 230TE, W116 450SEL, W639 119CDI, W201 190E
As long as the voltage drop is only marginal i.e. 1-2 volts it should be OK if the voltage drop is higher I would think one of the glowplugs has gone short circuit and needs to be replaced. if you remove them and check the resistance of each you can tell if any have failed open circuit or short circuit.
hockeyanimal56 is offline
    MCBear, could you make a midnight run over to Tenn. and take some heavies with you... Jakarta Expat Off-Topic 2 11-16-2007 12:16 PM
    LA residents make a run on Country Wide Bank cmitch Off-Topic 0 08-19-2007 07:00 AM
    Make your car run on water not gas. DETANE W163 M-Class 31 05-02-2007 03:34 AM
    Determined to make this thing run! Scotty15 W123 E,CE,D,CD,TD,TE Class 6 08-11-2004 07:17 AM
