W110 Heckflosse Project (1966 200) - Page 15 - Mercedes-Benz Forum
post #141 of 146 (permalink) Old 10-28-2015, 02:47 PM Thread Starter
Date registered: Jun 2010
Vehicle: 1966 MB 200; Porsche 914 (6); Porsche 914 (Chev 350); 36 ford
Quoted: 19 Post(s)
From what I understand, the sound deadening material, is more of a damper, and not insulation (absorption) against sound. So, even a small patch on a large flat panel will dampen or reduce the resonant frequency of that panel, hence quieter. Also, will dampen any reflected sound waves.
The secondary affect is absorption, resulting in a reduction in noise. I could not find any numbers about the amount of absorption, even on the dynamat site...
So, using this facts, you don't need to "seal" the entire surface, and as Nate suggested, it's fine and best to leave some gap from certain areas.
And if overall noise is the goal, the underhood seems to be the biggest offset. (Surprise!)
Reference: Putting Dynamat to the Test in a Ford F-150
It's going to be interesting, and I want to do this in steps and see the affects. The one recommended area, that I will not be doing, is the headliner. Sometime in the future, when I get that redone, I will install mat there. but not before.
Would be interested in any ideas. (and counter-ideas.)
-- brett
bfrymire is offline
post #142 of 146 (permalink) Old 10-29-2015, 05:27 AM
vwnate1's Avatar
Date registered: Jul 2006
Vehicle: European 1974 350SLC ,'78 300CD& '80 300CD sold , '81 240D SWMBO's Car '84 300CD & Euro
Quoted: 20 Post(s)
Post Quietude
Just so Brett ~
The idea is to halt the sheet metal's tendency to drum .
For temperature control , it's best to create dead air in the doors , etc. by using those plastic sheets .
You'll find the roof panel is an important spot to have insulation against noise but I never touch a good original headliner to install it , only when I'm having it replaced do to wear /rips .
bfrymire likes this.
-Nate
Old German cars & motos
vintage car mechanic
Gearhead
vwnate1 is offline
post #143 of 146 (permalink) Old 10-29-2015, 01:18 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
I found in my black V8 finny that it was getting very hot, and having under-bonnet insulation was making things worse, so I removed it. But the coupe is getting a 280SE motor (that I hear are also prone to getting a bit hot), so I will see what the noise level is like before doing anything there.
As for the roof, well I did that on the black finny too - but with the heat it gets, I am guessing that some of the insulation must have released, as now when I open my sunroof I get drag marks of the green glue used on the insulation. So that did not go too well.
Cheers, Drew
drew56cus is offline
post #144 of 146 (permalink) Old 11-01-2015, 04:38 PM Thread Starter
Quoted: 19 Post(s)
Not much progress, as it's mostly prep and getting the interior apart.
A couple of pictures showing the extent of the "hole" that was required to fit the 6 speed. I have a picture with the crude cover and without it. So, it's pretty obvious why it's so noisy in the car.
One other small thing that is annoying, I tore one of the seats as I was getting it out. that should not have happened. It's just cheap re-upholstery on the old seats. Very, very thin material.
Only had a couple of hours this week to work on it. So, this will be slow progress.
-- brett
ID:	1663097   Click image for larger version
bfrymire is offline
post #145 of 146 (permalink) Old 12-25-2016, 08:33 PM Thread Starter
Quoted: 19 Post(s)
To all my Mercedes friends, Happy Holidays!
And for Mercedes content, here's a very recent picture of it at work. It's weird parked next to a bunch of Tesla's.
I will post some more pictures this week with the more recent changes. New AC installed and working.
-- brett
bfrymire is offline
post #146 of 146 (permalink) Old 12-26-2016, 07:28 AM
vwnate1's Avatar
Quoted: 20 Post(s)
Looking good ! . thanx for the up date .
-Nate
Gearhead
vwnate1 is offline
Parting Out 1966 Mercedes 200 Heckflosse/fintail/110, Vancouver, BC chris196823010 For Sale/Wanted/Trade/Giveaway 9 09-10-2013 03:08 PM
1967 Heckflosse W110 230 for sale Berlinerheckflosse For Sale/Wanted/Trade/Giveaway 0 09-03-2007 07:43 PM
1967 Heckflosse W110 230 for sale Berlinerheckflosse For Sale/Wanted/Trade/Giveaway 0 08-18-2007 03:26 PM
FS: 1966 200 D FINTAIL AMSOIL300CDT Vintage Mercedes-Benz 1 11-15-2005 03:23 PM
1966 Mercedes 200 D FINTAIL AMSOIL300CDT For Sale/Wanted/Trade/Giveaway 1 11-12-2005 05:07 PM
