W110 Heckflosse Project (1966 200) - Page 13 - Mercedes-Benz Forum
post #121 of 146 (permalink) Old 03-31-2015, 03:05 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
Hi Brett,
Good to see some progress.
Could you please tell me a bit more about he handbrake you installed? A friend has a finnie with an M117 5L V8 which rendered the original handbrake mechanism unusable. He got a generic handbrake that looks like yours from a hot rod shop (maybe it a lokar one?) but it does not have enough cable travel to operate the finnie brakes. Did you have this issue, and if so, how did you overcome it?
Cheers,
Drew
drew56cus is offline
post #122 of 146 (permalink) Old 04-01-2015, 07:15 PM Thread Starter
Date registered: Jun 2010
Vehicle: 1966 MB 200; Porsche 914 (6); Porsche 914 (Chev 350); 36 ford
Quoted: 19 Post(s)
Nate,
The gauges are way more complicated by adding the C230 engine. The speedo is mechanical, and the C230 trans has a VSS. I will need to convert the VSS to a mechanical cable with a motor to get it to work. The only solution commercially available is about $1000.
The water temp is a capillary, not the tradition gauge/sensor. And the real problem there, is the capillary is broken. About $500 from mercedes (or maybe more since it's been a while since I checked.)
I have not looked in to the oil pressure, so, that may be easy to do.
And the gas gauge is funciton, but it WAY off. When it's full, it says 1/2.
Still, fun to drive, and I get thumbs up from other car guys.
-- brett
bfrymire is offline
post #123 of 146 (permalink) Old 04-01-2015, 07:20 PM Thread Starter
Quoted: 19 Post(s)
Drew,
Glad to hear from you!
Yes, it's a Lokar unit, and I have the similar problem. Not enough travel. We fussed with it for a while, and got it somewhat working. It will hold the car on a slight incline, but anything other than that, it will not hold. It's enough to hold the car on the driveway, and I keep it in gear as extra precaution.
I do plan to fuss with it some more and see if I can get it to work better.
After I had selected this item, I found an electronic brake, that looks like it might be better. Just has a push button switch to activate it.
E-Stopp Brake
Summit and Speedway both carry it.
-- brett
bfrymire is offline
post #124 of 146 (permalink) Old 10-12-2015, 12:50 AM Thread Starter
Quoted: 19 Post(s)
Car Meetup in San Jose
Took the mercedes to Ronnie's Getogether at Camden/Hillsdale. Mosly american Iron, but I wasn't the only mercedes there.
I just got a carpet kit from World Upholstry and will be working on installation. I have fatmat and will be putting that down first. Right now, the car is way too loud inside. Can't hear the stereo at freeway speeds. And the car originally came with rubber flooring, so the fatmat and carpet should help a lot.
bfrymire is offline
post #125 of 146 (permalink) Old 10-12-2015, 09:06 PM
vwnate1's Avatar
Date registered: Jul 2006
Vehicle: European 1974 350SLC ,'78 300CD& '80 300CD sold , '81 240D SWMBO's Car '84 300CD & Euro
Quoted: 19 Post(s)
Thumbs up Show & Shine
Looks good ! .
What are the chances of some pix of the fat mat and carpet installation ? .
-Nate
Old German cars & motos
vintage car mechanic
Gearhead
vwnate1 is offline
post #126 of 146 (permalink) Old 10-12-2015, 09:50 PM Thread Starter
Quoted: 19 Post(s)
Thanks Nate,
Yes, I plan on lots of pictures, and details about the install. I have new seats, and new carpet to install. I also need to fabricate a floor, as there is a big hole there, with badly formed sheet metal over it.
I should be able to start the install, the week after next. Stay tuned...
-- brett
bfrymire is offline
post #127 of 146 (permalink) Old 10-12-2015, 11:24 PM
vwnate1's Avatar
Quoted: 19 Post(s)
Thumbs up Ongoing Repairs
Thanx go to you Brett ;
For the detailed information .
No matter what it is , I always learn from reading others technical posts .
I'm a big fan of adding insulation and sound deadening mats , always have been since the days o asphalt soaked horse hair pads.... (nasty yes but they didn't retain moisture and stopped sheet metal from drumming) .
So ' Fat Mat ' sounds interesting to me .
-Nate
Gearhead
vwnate1 is offline
post #128 of 146 (permalink) Old 10-14-2015, 11:55 PM Thread Starter
Quoted: 19 Post(s)
You bet Nate! There is a lot to do, but I do plan on posting more photos and details.
I bought the fatmat kit which includes 50ft of the fatmat, and a roller and other tools to assist. And the german square weave carpet kit from World Upholstry.
Pictures to start with. Can't start this weekend, but should be able to start the following weekend.
-- brett
ID:	1645017   Click image for larger version
ID:	1645025   Click image for larger version
bfrymire is offline
post #129 of 146 (permalink) Old 10-15-2015, 06:16 AM
vwnate1's Avatar
Quoted: 19 Post(s)
Thumbs up Carpet & Insulation
Thanx ! .
Will you be installing any Fatmat inside the doors ? .
I always find that makes it quieter by reducing the sheet metal drumming .
-Nate
Gearhead
vwnate1 is offline
post #130 of 146 (permalink) Old 10-15-2015, 11:05 PM Thread Starter
Quoted: 19 Post(s)
More than likely, yes. Depends on how much I have left after doing the floors. Good thing, the doors only need a small patch to be effective.
-- brett
bfrymire is offline
    Parting Out 1966 Mercedes 200 Heckflosse/fintail/110, Vancouver, BC chris196823010 For Sale/Wanted/Trade/Giveaway 9 09-10-2013 04:08 PM
    1967 Heckflosse W110 230 for sale Berlinerheckflosse For Sale/Wanted/Trade/Giveaway 0 09-03-2007 08:43 PM
    1967 Heckflosse W110 230 for sale Berlinerheckflosse For Sale/Wanted/Trade/Giveaway 0 08-18-2007 04:26 PM
    FS: 1966 200 D FINTAIL AMSOIL300CDT Vintage Mercedes-Benz 1 11-15-2005 04:23 PM
    1966 Mercedes 200 D FINTAIL AMSOIL300CDT For Sale/Wanted/Trade/Giveaway 1 11-12-2005 06:07 PM
