1962 220SE 111014 possible fuel delivery issue - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-03-2010, 01:34 PM Thread Starter
Date registered: Sep 2010
I just drove from Kansas City to my home in Denver and the Benz ran great except it would only run well on a full tank! I'd fill the tank and be good for 80, 90, 100 miles and it would start to hesitate as if it wasn't getting enough fuel. Then I would top off the tank and it would, once again, run great.
Any ideas where I should start to look for a cause?
Weak pump? Not enough pressure?
Thanks guys, I'm glad to find this forum!
Todddennison is offline
post #2 of 3 (permalink) Old 09-04-2010, 07:01 AM
wbain's Avatar
Date registered: Dec 2003
From the description, the tank has rust and bits are clogging the fuel pump inlet screen, by the rear axle. There are home kits available, such as Eastwoods, or have it done professionally. The injection pump also has an inlet screen as does the cold start valve.
A clean fuel system is vital for the injection system due to the tight tolerances.
Please update your profile. A pic or two would help as well.
wbain is offline
post #3 of 3 (permalink) Old 09-04-2010, 09:52 AM
Good advice WaltB, and
Todddennison, pull the plug in the bottom of the fuel tank. to check the screen.
The plug will be tight, needs big leverage.
I made a hex wrench tool from a 22mm or .875 (7/8) bolt head with two nuts jammed on.
The tank will drop out very easily. three fasteners maybe one on the side if it is the big tank
Brian O
bostosh is offline
    380 SL Fuel delivery issue?? johnk1366 General Mercedes-Benz 0 03-07-2010 05:41 PM
    220se fuel injectors Redpawn Vintage Mercedes-Benz 4 05-04-2009 12:48 PM
    92 2.3 190 Fuel Pressure/Delivery Issue kregghill W201 190-Class 3 09-17-2007 01:05 PM
    92 190 2.3 Fuel Pressure/Delivery Issue kregghill General Mercedes-Benz 0 09-14-2007 01:26 PM
    For Sale: 1962 Mercedes 220SE fintail parts car in the San Francisco area DavidT Vintage Mercedes-Benz 0 05-26-2006 10:31 AM
