Throttle Linkage Bushings (under hood) - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-25-2010, 09:12 AM Thread Starter
Date registered: Aug 2010
Hello, We're having a difficult time finding throttle shaft bushings for an older model. The MB is 1970, 300SEL, 3.5 liter motor, fuel injected. The bushings are missing so can't describe them. The bushings support the long link from a bracket on the firewall (spring loaded at this end) to a boss cast into the intake manifold. This is the longest link in the throttle maze. I imagine a plastic marble of about 1/2" to 3/4" in diameter, cot in half with about a 5/16" hole drilled in the center. The rod would enter the flat side. I have gotten (wrong) a plastic grey spherical bushing with two small pins on it. This is for the accelerator pedal (I think) and not what is needed under the hood. Thanks for any help in advance......Steve
sedgar2 is offline
post #2 of 5 (permalink) Old 08-26-2010, 10:05 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Go to the EPC and find the part numbers for what you want. The Classic Center can probably still get them for you.
'59 220S Cabriolet - for sale -
'83 240D original owner 351,500 miles - for sale -
'88 560SL 41,000 miles being parted out -
'99 E300 turbo 196,000 miles
'03 SLK320 34,500 miles
'14 Smart electric
sokoloff is offline
post #3 of 5 (permalink) Old 08-26-2010, 01:20 PM Thread Starter
Question You lost me!
What's 'EPC"?
sedgar2 is offline
post #4 of 5 (permalink) Old 08-27-2010, 04:55 AM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 37 Post(s)
Originally Posted by sedgar2 View Post
What's 'EPC"?
Electronic Parts Catalog. EPC-net Online
Part number for bushing is 126 300 00 85 or 126 301 04 85 plus 116 301 01 50.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #5 of 5 (permalink) Old 08-31-2010, 04:24 AM Thread Starter
Throttle Bushings Solved
The bushings needed are used to support the rod (366 in parts blow-up). These were missing and the throttle rod was flopping around in the brackets. The solution turned out to be a fabrication. I got a bathroom sink drain repair kit. The kit has three different diameter plastic spheres and a rod to fix the stopper in a bathroom sink. The largest diameter ball was just right to fit mined. In a drill press (with vise) the proper size holes were drilled and a metal washer was added to keep the spring away from the plastic. Then the rod was lubed and fitted into the two brackets and so far it works best kind! Thanks for all the responses and if anyone needs more info, don't hesitate......Kind Regards
sedgar2 is offline
    Auto trans shift linkage bushings. Cefalu W123 E,CE,D,CD,TD,TE Class 9 06-04-2013 08:28 AM
    Shift linkage bushings dugald R/C107 SL/SLC Class 10 12-18-2010 08:41 PM
    does the trans shfit linkage suppose to have bushings LIV2RIP W124 E,CE,D,TD Class 7 02-17-2010 03:47 AM
    Bad shift linkage bushings? markwill W210 E-Class 2 01-18-2008 02:56 PM
    Bushings on the Auto shift Linkage timlee W124 E,CE,D,TD Class 8 09-12-2002 11:26 AM
