HELP! Glowplug broke when driving - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-24-2010, 11:30 AM Thread Starter
Date registered: Apr 2008
Vehicle: 93' 300e 2.8/ 86' 190e 2.3-16v X 3 / 66' 200D fintail
Sorry if this is a dumb question this is my first diesel car and this was on my first drive in it the questions pertains to a 1966” 200D with an om621
I was driving north bound Interstate 5 in WA state , I was accelerating in 4th gear coming up to about 50mph when I started to hear what sounded like an exhaust leek I backed off a little bit and the sound went away then so I put my foot back down and it made a loud POP sound fallowed by a rhythmic popping sound Very load almost like a rod knock, I let it coast as I pulled off the road open the hood and found the glow plug had broken and the pencil part was sitting out of the block with the rest still in the side of the block, appeared as if the center got blown out
2 different friends of mine both certified diesel mech’s told me that I didn’t need to be worried about the Popping sound as it was just all the pressure forcing its way out of the glow plug hole, since the sound went away without throttle and low engine speed
Questions: is has this ever happen to anyone else? And if so is this a common thing if you replace the old loop style glow plugs with the newer pencil style? What may have caused this to happen ?
Thank you for your time in reading this thread
veedubfreak86 is offline
post #2 of 6 (permalink) Old 09-01-2010, 09:16 AM Thread Starter
anybody ???????
post #3 of 6 (permalink) Old 09-01-2010, 06:10 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Quoted: 2 Post(s)
I have heard that the pencil upgrade plugs are not as good as the old loop in terms of durability. So im sure it was just a faulty glowplug.
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
post #4 of 6 (permalink) Old 09-02-2010, 11:54 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Sometimes if injectors are not good, they will spray directly on the glow plug and that is not good for the glow plug (or the prechamber).
It happened only once to me, but not during driving. I tried to remove an old glow plug out of an engine and the front part was stuck in the engine, the rest came out.
Govert70227 is offline
post #5 of 6 (permalink) Old 09-03-2010, 10:09 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1548 Post(s)
Glowplugs can also become fatigued and break when people foolishly spray starter fluid in the intake to help fire it up on a cold morning or after sitting for a while. I'm not sure why a pencil type plug would be less sturdy, as these basic designs have been in use for the last 30+ years with very little changes.
I have a complete set of used pencil type plugs and hardware from my old '73 220D w/OM615 engine if you're interested--cheap. I believe they're the same design. I'm in Olympia
Zeitgeist is offline
post #6 of 6 (permalink) Old 09-08-2010, 02:09 PM Thread Starter
this may be the case as i did use starter fluid to add in getting it going since it has a cylinder with low comp , ............. i maybe intrested i will get back to you
    Camshaft Broke while Driving figgi01 W201 190-Class 10 09-13-2009 08:03 PM
    glowplug replacement curbill W123 E,CE,D,CD,TD,TE Class 5 02-01-2009 06:41 PM
    Glowplug garySDL W126 S,SE,SEC,SEL,SD,SDL Class 1 05-12-2008 12:50 AM
    SCARY- Ball Joint Broke while driving!!! satyr W201 190-Class 10 07-12-2005 09:47 AM
    Cold front finally broke heatwave, beautiful top down driving in Houston! Norb R170 SLK-Class 2 05-14-2002 06:35 PM
