76 300D power window fix? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-24-2010, 10:13 AM Thread Starter
Date registered: Aug 2010
I have a 1976 300D on which the drivers rear and pass front window will stop working at the same time. The longer I let the car sit un-driven or with the battery disconected, they both will work again for about 3 cycles, then they both quit at the same time! what is the common link between these two windows. I've tried replacing the switches with good know units and i've jumped power to the motors and gotten nothing... I find it hard to believe they both went bad at the same time, and why would they both occasionally work also. Any help would be greatly appreciated, thanks!
Torr Nado is offline
    Power window problem in W124 (300D Turbo '92) Guest (MBNZ) W124 E,CE,D,TD Class 3 01-03-2015 07:08 AM
    300D power window conversion to manual plosada Vintage Mercedes-Benz 1 08-03-2010 03:58 AM
    Where is power window relay for 300D? Dave300D W123 E,CE,D,CD,TD,TE Class 2 07-28-2008 03:29 PM
    How to fix sunken power window switch on console? rph74 W126 S,SE,SEC,SEL,SD,SDL Class 6 05-17-2007 11:08 AM
    300d tach fix pondscum007 W123 E,CE,D,CD,TD,TE Class 3 03-31-2003 07:34 AM
