1979 300sd door locks dead - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-23-2010, 09:29 AM Thread Starter
Date registered: Jun 2010
Vehicle: 1979 300SD Turbo Diesel
After searching the forums, I could not find the answer. When I pull the handles from the outside, two of the doors will not open even though they are unlocked. They open from the inside. I took the whole lock assembly out of the door and it looks like the "puller" from the outside will not move the metal "stopper" out of the way when the outside handle is pulled.(holding the latch in place) It works when the inside handle is pulled. I adjusted the outside handle by the screw and it seems the problem in in the lock mechanism itself. Do I replace the whole mechanism? I cannot find one online. Suggestions? And thanks. William 1979300sd
williamcary is offline
    Problem with door locks 1984 300SD Help Please sg1809 W126 S,SE,SEC,SEL,SD,SDL Class 28 04-02-2012 08:10 AM
    1979 300sd, getting door panel off gristle W116 S, SE, SEL, SD Class 2 02-05-2009 06:11 PM
    ??300SD Vacuum Door Locks Questions?? Ian White W126 S,SE,SEC,SEL,SD,SDL Class 1 11-26-2008 01:13 PM
    Question RE Interchangeable parts 1979 300SD - 1983 300SD Reedfarm W126 S,SE,SEC,SEL,SD,SDL Class 2 10-03-2004 08:03 PM
    '85 300sd door locks, please read! Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 5 09-03-2003 11:21 AM
