Help with bulb replacement in 1969 Euro (vertical) headlights - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-22-2010, 06:23 PM Thread Starter
BRosenbaum's Avatar
Date registered: Aug 2010
Vehicle: 1969 280SE Coupe Euro Model
Does anyone have experience changing lightbulbs in old (1969) vertical Euro lights? Once the glass is removed does the reflector come off or does the entire unit need to be removed from the bucket to change the bulb?
BRosenbaum is offline
post #2 of 5 (permalink) Old 08-23-2010, 11:07 PM
4.5_sport's Avatar
Date registered: Apr 2004
Vehicle: 1994 E320T, 1979 VW Rabbit
Send a message via MSN to 4.5_sport
You don't need to remove the glass. Just undo the 4 Phillips screws that hold the assy to the fender. The bulb holder just twists and you can remove the bulb...
4.5_sport is offline
post #3 of 5 (permalink) Old 08-29-2010, 07:34 PM Thread Starter
BRosenbaum's Avatar
Thank you so much. The next task is to get the replacement bulbs to fit in the holder (not an exact match as the new ones have three ears versus a solid flange - the three ears almost, but not quite, match up with those on the reflector).
post #4 of 5 (permalink) Old 08-29-2010, 07:53 PM
4.5_sport's Avatar
My solution for that was to melt the solder and separate the base of the old bulb from the bulb itself; l put the base of the old bulb back into the reflector. Then I cut the three ears off of the new H4 bulb and inserted it through the hole in the original base... reassemble, and viola... H4 bulbs in early euro housings.
post #5 of 5 (permalink) Old 08-30-2010, 10:32 AM Thread Starter
BRosenbaum's Avatar
That is a very clever solution.
On close inspection I found that one of the bulb ears fit into a small notch in the reflector (at 6 o'clock). Then the largest ear was close enough to fit into the retaining ring slot with the reflector's ear, and I could let the third bulb ear push against the reflector without interferring with the retaining ring and still attach the retaining ring to the other reflector ears.
However I will not toss the old bulbs, nor your kind advice.
Thank you!
560 SEC Euro Bosch Glass Headlights + DarkOrange Euro Corners dannysocal For Sale/Wanted/Trade/Giveaway 4 04-08-2011 09:06 PM
New Headlights, Dim bulb? ingydrummer W211 E-Class 2 02-25-2010 06:47 PM
w116 euro headlights/w126 sec euro headlight sebandwhit For Sale/Wanted/Trade/Giveaway 0 08-13-2009 09:50 AM
126 euro headlights and euro bumpers for sale 2.3-16turbo W126 S,SE,SEC,SEL,SD,SDL Class 11 08-06-2006 08:58 AM
Euro Headlights With Wipers? Euro Bumpers? ChadW123 W123 E,CE,D,CD,TD,TE Class 1 03-05-2003 04:30 PM
