200D (w110) engine trouble HELP - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-09-2010, 09:50 AM Thread Starter
Date registered: Apr 2008
Vehicle: 93' 300e 2.8/ 86' 190e 2.3-16v X 3 / 66' 200D fintail
Hello and thanks for looking
ok so i just bought a 66' 200D turns out cy# 2 has low compression i need to know if anyone has a spare engine they will part with (already posted in WTB thread)
if anyone has good info on what motor are easily swapped into the w110 chassis and what engines bolt to the 4 spd in the car, I have used search and found very little on this topic or on the 200d in general the only info I found (via google)was a guy in the UK that did a om617 in a w111
also not new to mercedes i use the same screen name on 190rev.net
just trying to find a sunday car
veedubfreak86 is offline
post #2 of 2 (permalink) Old 08-16-2010, 12:21 PM
Date registered: Jan 2007
Quoted: 82 Post(s)
A 200 gas will drop in and bolt up, as will a 230 gas, but you will have to move the radiator into the frame shell and add a tank back by the firewall. For other engines, you need to poke around in the EPC and see if they use the same bellhousing as your car, which I believe is 111 250 05 05 or 20 05.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
    WTB: 200D(w110) engine om621 veedubfreak86 For Sale/Wanted/Trade/Giveaway 1 08-10-2010 08:06 AM
    Ponton W110 200 diesel engine - need help please ifzal_uk Vintage Mercedes-Benz 4 01-23-2010 02:51 PM
    Euro 200d engine options? frogman W123 E,CE,D,CD,TD,TE Class 1 07-29-2008 07:50 AM
    Any W110 200D owners? baco99 Vintage Mercedes-Benz 5 05-26-2008 05:24 AM
    w123 engine replacement from 280ce to 200d lindemann W123 E,CE,D,CD,TD,TE Class 6 01-13-2008 11:55 AM
