Oil pump replacement W115 300D - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-05-2010, 06:45 PM Thread Starter
50 cool 50's Avatar
Date registered: Apr 2010
hi guys
pretty sure i got a failed oil pump
i'm gonna change it out over the weekend
i never done one before
is it dificult?
does anyone have any tips ?
50 cool 50 is offline
post #2 of 2 (permalink) Old 08-06-2010, 11:49 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
No, drain oil, take off oil pan, unscrew two bolt of the oil pump, take out oil pump, put in new oil pump, make sure it connects to the drive, but in the bolts, mount oil pan (torque bolts to 10 Nm), put in new oil.
Good opportunity to change the bypass oil filter and clean the main oil filter.
See also the FSM:
18 Engine Lubrication, Engine Oil Cooling - OM617
Govert70227 is offline
    1990 300D OM602 timing chain , vacuum pump . oil pump chain ? rkpatt W124 E,CE,D,TD Class 8 03-04-2012 11:49 AM
    300d injector pump leaking oil bens993 W123 E,CE,D,CD,TD,TE Class 11 05-26-2010 10:14 PM
    93 300D water pump replacement interval rx2man W124 E,CE,D,TD Class 0 11-15-2009 07:43 AM
    WTB: W115 Injection Pump Oil Filler Cap Benz_240D For Sale/Wanted/Trade/Giveaway 3 06-06-2008 02:39 PM
    Vacuum pump check valves replacement on a 1980 300D sokmister W123 E,CE,D,CD,TD,TE Class 3 11-07-2007 05:15 PM
