Gear whine in rear end - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-01-2010, 06:43 AM Thread Starter
Date registered: Jan 2010
Vehicle: 1975 240D
Among some compression issues that will ultimately lead me to an engine rebuild or replacement this winter, I am noticing a gear whine in the rear end. I am happy to fix, replace bearings, new axle shafts etc..., but I am not sure what is actually causing the problem. My local Mercedes mechanic is telling me it may be the rear diff gears are not mating properly due to wear causing the problem, but I do not know what that means or how to fix it.
nchobo is offline
post #2 of 4 (permalink) Old 08-01-2010, 01:27 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Pull the cover and look at the wear pattern.
renaissance_warrior is offline
post #3 of 4 (permalink) Old 08-31-2010, 11:15 PM
Date registered: May 2010
Vehicle: 1971 220D
I have the same whine and obviously louder at high rpm's. Let me know what you found out. I have a charging issue that I want to deal with before I get to this problem. In a couple of weeks maybe I can be of some help.
tchavez14 is offline
post #4 of 4 (permalink) Old 09-02-2010, 10:55 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
First check the oil, and best replace the oil in the diff.
Govert70227 is offline
    rear end gear ratios drmiller100 W123 E,CE,D,CD,TD,TE Class 5 11-24-2014 11:01 PM
    02 ml320 rear end questions (whine) jakell2010 W163 M-Class 5 05-09-2009 04:59 AM
    First gear whine Dlespera Vintage Mercedes-Benz 4 11-27-2008 03:00 AM
    I need a c32 rear end /gear ratio? HeirKranz W203 C32 AMG, C55 AMG 2 05-14-2007 10:57 AM
    Gear Whine/Bearing Whine? DOUGLAS MARTIN W123 E,CE,D,CD,TD,TE Class 2 05-14-2006 06:23 PM
