three A/C compressor and still no A/C on my 240D - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-26-2010, 03:23 PM Thread Starter
Date registered: Jan 2010
Vehicle: MB 240D 1980, Citroen 2CV 1966
Hi! I am very frustrated. On Dec, 2009 I got a 240D 1980 in very good condition.
Only 55.000 miles on it. Everything was working except the A/C. The car was seat on a garage for 5 years before I purchased it. They started the engine sometimes untill battery became dead. The car still had the system for R12 burt no freon inside at all.
The first thing I did with the A/C was to partially flush the hoses and put a new dryer. I changed the O-rings for the green ones ready for the R134a. I put 4 ounces of comp. oil PAG 60 in the compressor, a Fourseasons, not the original that came with the car in 1980, (but no oil in the dryer)and did a vacuum for about ten minutes. Then I charged the system with two cans of R134a and some dyer in case was any leaks. Everything seemed to work fine for about ten days. Temp. out of the outlets was 40ºF. On the 11th day a noticed some oil on the ground and all freon was gone. The compressor was broken.
Second attempt to fix the A/C on the car. This time I collected more inf. I ordered a remanufactured comp. from a company in eBay. I flushed the whole system and installed a new expansion valve. I put 4 oz of oil in the compressor and 4 oz in a new dryer. (PAG 100) I did a more extensive vacuum for about 30 min. and put 2 ½ cans of R134a I also installed a new A/C fan in front of the condenser because I noticed that the original fan was not working. I also installed a new A/C cutoff switch L 2 Kgs H 20 Kgs
Again good cold air (40ºF) for another 5 days and after that the compressor passed away. Same faliure, I sow some oil in the ground under the compressor and all freon was gone.
The third attempt was similar to the previous one, but this time a put a new Fourseasons compressor $200.00 fron Advance Auto Parts in the Web page, another new Dryer and the same expansion valve. I did flushed the system again, I put PAG 160 this time according to inf. from the comp. company and did the vacuum again. This time the compressor worked only four days. In the morning of the fifth day the compressor exploded only a few minutes after a started the A/C.
I read extensively in the forums and it seems like the system is not going to work fine with R134a eventhough the expansion valve has a sticker that reads R134a.
I returned the compressor to Advance, they will send me a new one and this time I want to try with R12. and some mineral oil.
What is your advice for my case?
Thanks a lot.
consufe is offline
post #2 of 3 (permalink) Old 07-29-2010, 06:56 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Not sure what compressor you have but by now you probably know that the older piston type compressors like the A6 or York can't take the higher pressures that 134a operate at. Also I have heard that fourseasons compressors have a bad reputation.
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #3 of 3 (permalink) Old 07-30-2010, 04:35 AM Thread Starter
Angry 3 a/c compressors
Thanks Tony:
the a/c compressor type my 240D 1980 uses is the R4 from which i read not very good comments. In others words it is not a good quality compressor.
I diddn't heard anything about Fourseasons reputation as a/c compresor's manufacturer.
consufe is offline
    ANyone know how to replace compressor clutch on OM617 while compressor still attached to loss W123 E,CE,D,CD,TD,TE Class 16 06-22-2010 09:26 PM
    82 240d air conditioner compressor help 240biodiesel General Mercedes-Benz 0 07-13-2008 07:24 PM
    `81 240D A/C compressor removal Nardo W123 E,CE,D,CD,TD,TE Class 0 01-03-2007 03:00 PM
    can i change the stock a/c compressor with a non oem compressor? eso7 W123 E,CE,D,CD,TD,TE Class 6 01-18-2005 05:19 PM
    $15 5-in-1 air compressor for those that bought used SLKs with missing compressor Black98SLK230 R170 SLK-Class 2 11-29-2004 03:20 PM
