Seized 220 What Now? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-24-2010, 06:19 AM Thread Starter
dame's Avatar
Date registered: May 2010
Vehicle: 1968 220
Hi, I have a 1968 220, the 4cyl. It has seized and I am guessing I need a new engine. What are my options? Can I stick a 6cyl in it or should I just try and find the same???? What should I do?
Thanks
dame is offline
post #2 of 4 (permalink) Old 07-24-2010, 02:31 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
The rear differential ratio is probably not the same between the four and the six cylinder, so you need to change that as well.
You might need different front springs.
Govert70227 is offline
post #3 of 4 (permalink) Old 07-24-2010, 03:39 PM
wbain's Avatar
Date registered: Dec 2003
At that time there was a 230/8 and a 250/8 which were 6 cyls. There are two rods from the chassis to the firewall so don't remove them. MB put them in there to reduce vibration and chassis flex. Find a 6 cyl from the 230 or 250 and replace the bad engine.
Why did the original engine seize?
wbain is offline
post #4 of 4 (permalink) Old 07-24-2010, 08:57 PM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
W114/W115 chassis are very similar to the r107 one (front subframes are the same). Any V8 fitted in an r107 will drop right in. I would go for an alloy block version though to save weight on the front.
Check this: Merc W114 V8
GGR is offline
    The badge is 220 CE but the paper says 220 SE but doesn't look like one! HELP! joshes Vintage Mercedes-Benz 31 02-19-2009 08:28 AM
    eBay: AMG 220, AMG 230 18" Wheels + 220 Steering Wheel Aristotle For Sale/Wanted/Trade/Giveaway 0 08-10-2007 09:56 AM
