1972 280 SEL 4.5 fuel pump problem? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 07-17-2010, 04:46 PM Thread Starter
Date registered: Apr 2009
Vehicle: 1972 Mercedes Benz 280 SEL
I took my 1972 280 SEL 4.5 out for a spin on the Interstate today and stopped by my office on the way home. When I returned to the car, it wouldn't start. I cranked and cranked and finally decided to put the gas pedal all the way down. It started, but ran pretty rough. On the way home, it stalled when I would stop. I made it home and drove the car into the garage, keeping my foot on the gas so it wouldn't stall. It blew out bluish smoke at idle and finally stalled. When I got out, I noticed a sound coming from just behind the left rear tire. I looked under the car, and the buzzing/humming sound was coming from the fuel pump.
Does the fuel pump run after the car is turned off? Could the fuel pump be failing and creating a fuel pressure problem? A mechanic told me the last time that the car was running way too rich. Also there was a paint-like smell coming from fuel pump area.
Help is appreciated.
Packard1807 is offline
post #2 of 10 (permalink) Old 07-18-2010, 06:11 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Paint-like smell from the fuel pump area? How old is your gas?
I'd suggest taking out your spark plugs to inspect them. If you're running rich, chances are excellent you have fouled plugs. Additionally, if they're oil fouled, you might have an issue with your rings.
What kind of milage are you getting?
And yes, when your turn the key off, the fuel pump should stop.
Grubeguy is offline
post #3 of 10 (permalink) Old 07-18-2010, 01:20 PM
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
If you are blowing blue smoke, that means that you are getting way too much fuel. I would suggest that you check the vacuum line to your fuel pressure regulator and change your oil, as it is probably contaminated. Your fuel pressure regulator shoild be replaced if the vacuum line is intact.
renaissance_warrior is offline
post #4 of 10 (permalink) Old 07-18-2010, 03:23 PM Thread Starter
The gas is a couple of months old. The compression on all cylinders is good. Mileage has always been poor - 10 to 14 mpg.
What's wierd about the fuel pump is that it made a buzzing sound which slowly went away. I put my hand on the fuel pump and it didn't feel like it was running, but the sound was definitely coming from it.
Today I tried to start the car and the same thing happened. I always started right off, but on the first crank it quickly fires but then nothing. It just seems like this is fuel system related, especially if the fuel pump was making a noise. Could it be a fuel pump relay issues? The fuel pump actually looks quite new.
post #5 of 10 (permalink) Old 07-18-2010, 03:26 PM Thread Starter
Thanks. I will check the vacuum line. Any ideas why the fuel pump would make a buzzing sound after the car has been shut off?
post #6 of 10 (permalink) Old 07-18-2010, 03:52 PM Thread Starter
Is there a way to clean fouled plugs or should they be replaced?
post #7 of 10 (permalink) Old 07-19-2010, 03:30 AM
Grubeguy's Avatar
Quoted: 99 Post(s)
The SEL's fuel regulators don't have a vacuum input - they're inline, spring regulated devices.
I'm wondering if you have some sort of a clog after the fuel pump. If you hear a buzz but the pump isn't running, maybe it's return pressure going through the pump, back to the tank... Anyone remember if there's a check valve in the pump?
For fouled plugs, I've used acetone (nail polish remover) and mild sand paper to de-foul the things. You may need to regap them though.
I agree with changing the oil too - running rich causes the fuel to mix with the oil in the cylinder, which thins out the oil.
Grubeguy is offline
post #8 of 10 (permalink) Old 07-28-2010, 07:47 PM
67 300's Avatar
Date registered: Oct 2008
Vehicle: 73 450 SE Euro
Make sure to check the map sensor make sure the hose isnt cracked, you wont get proper fueling to engine without the right pressure readings had sort of the same problem on my 73 450 sel same engine/trans. Cheers and good luck, bro..
67 300 is offline
post #9 of 10 (permalink) Old 07-28-2010, 08:30 PM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 109 Post(s)
It it suddenly started running like crap, check the ignition points gap and condition, it may be either dirty or out of adjustment and would do exactly that.
With best regards
Al
Check out the W114, W115 /8 enthusiast forum http://www.stroke8.org
My 280SL restoration
alabbasi is offline
post #10 of 10 (permalink) Old 08-24-2010, 09:03 AM Thread Starter
Is there a pcv valve on the 1972 4.5 V8?
    72 280 SE 4.5 - Fuel Pump Problem 1972 280 SE 4.5L Vintage Mercedes-Benz 0 01-29-2007 09:54 AM
    280SE 1972 Fuel Damper, pump, system, Problem? Floydf Vintage Mercedes-Benz 4 10-04-2006 08:57 PM
    1972 280 SEL For Sale dwjohnsonkb For Sale/Wanted/Trade/Giveaway 0 01-02-2006 07:55 AM
    1972 280 SEL For Sale dwjohnsonkb For Sale/Wanted/Trade/Giveaway 0 01-02-2006 07:50 AM
    F.S. 1972 280 SEL 4.5L willis5275 For Sale/Wanted/Trade/Giveaway 2 06-12-2005 04:58 PM
