HELP!!! no spark!! - Page 3 - Mercedes-Benz Forum
post #21 of 23 (permalink) Old 07-22-2010, 10:19 PM Thread Starter
hugedodge2000's Avatar
Date registered: Jan 2010
you think a thick enough coating of teflon tape would work or should i use something else?
hugedodge2000 is offline
post #22 of 23 (permalink) Old 07-22-2010, 10:22 PM
eric242340's Avatar
Quoted: 283 Post(s)
You will have to use a form of insulation that is locally available, plastics work well.
eric242340 is online now
post #23 of 23 (permalink) Old 10-27-2010, 06:29 AM
Date registered: Oct 2010
ignition upgrade time?
Sounds like the problem I recently had. I thought I could handle it as I was raised in the good old days with points and condensor with dwell and tach meters. I got so frustrated I wanted to scream. A friend told me to give in and upgrade to electronic ignition. I thought $$$ but check this out. Google Hot Spark igngtion and look at their product. I ordered the upgrade and new high power condensor and for less then $100 the car runs smooth as I have ever seen. No expensive controll unit, no condensor points or anything to wear out or adjust.
curtisl is offline
    Spark plug, spark plug wires nsupra W210 E-Class 21 09-06-2009 07:35 PM
    Spark Plugs & Spark Plug Wire Reccomendations danger450 R170 SLK-Class 2 02-19-2009 06:02 PM
    no spark JA560SL R/C107 SL/SLC Class 3 05-20-2008 10:16 AM
    What Spark Plugs? Spark Plug gap? Spark plug used? hilarushi W210 E-Class 4 03-29-2007 11:42 PM
    No Spark r00ster W201 190-Class 1 10-29-2006 04:42 PM
