'62 220SE torque specs for head bolts, rod bolts? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-09-2010, 02:06 PM Thread Starter
Date registered: Oct 2009
Hello all,
I'm having trouble finding this information. I'm refitting the pistons and the head for my 1962 220SE coupe, and I need to to know the torque specs for the rod bolts and head bolts (including the small allen-head bolts used on the head). I suppose I could also use torque specs for the oil pan bolts (the ones that hold the entire pan to the block).
I'm also looking for a valve stem seal set for this car. I've only found two sources (Autohaus AZ and CarPartsDiscount), and both are backordered, with an expected delivery of 1-2 months. Any other sources for these?
scottreams is offline
post #2 of 3 (permalink) Old 07-09-2010, 05:05 PM
Govert70227's Avatar
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
It is on the Factory Service Manual:
Rod bolts 37 Nm
Head bolts 78 Nm cold engine. Run engine hot until 80 degrees Centigrade, then 88 Nm. It needs retightening after 300-1000 km. Loosen bolts (one by one) before retightening. Drench the bolts and nuts in oil.
The allen bolts don't have a specific torque. See the note on the second picture: use a hand key it says in German.
The values below are in mkp, for Nm or lb/ft use conversion tables/website.
Govert70227 is offline
post #3 of 3 (permalink) Old 07-10-2010, 11:37 AM
Date registered: Jul 2010
Vehicle: 1964 Mercedes Benz 220 S
you might be able to get the valve stem seals through the classic center, I would email them as I never get anyone via the call line. the address is Mercedes-Benz - Home of C, E, S, CLK, CLS, CL, SLK, SL, SLR, R, GLK, M, GL, G Class - Heritage - Classic Center this is a good resource for new parts.
jdb_333 is offline
    Please help - what are the head bolts torque settings on an SLK 230 PeteN69 General Mercedes-Benz 1 06-13-2010 11:42 PM
    Need torque specs for distributor cap bolts. D.T. W140 S-Class 1 06-08-2010 06:03 AM
    Rod Bolts deep3175 General Mercedes-Benz 3 05-13-2010 05:50 AM
    '99 R170 Cylinder head bolts torque wrench settings rangelo R170 SLK-Class 8 07-09-2008 07:37 AM
    Transmission bolts torque specs neonflx C208/A208 CLK-Class 0 05-25-2004 09:04 AM
